HAS ANYONE GONE FROM L98 HEADS TO VORTEC HEADS???
Car: 2KGTP
Engine: supercharged 3800 L67
Transmission: 4T65E
Axle/Gears: 2.93
What is your setup? Did you like the results? How much of an improvement did it make?
1986 CAMARO Z28 -> 151,000 original miles, 43,000 on 89' vette 350 block, Holley 650 DP, Weiand intake, 1.6 rockers, 1 5/8" headers, no cat, 2 1/2" Flowmaster catback, Mallory coil, March pulleys, T5 with 3.35 1st gear, 90% Centerforce clutch, 3.73 posi, Eibach 1" drop springs, Spohn LCA's, Spohn adjustable panhard rod, Subframes connectors, polyurethane swaybar bushings/endlinks, 2 12" Sound Streams, 2 Infinity 6X9's, 2 Pioneer 6X9's, 800 watt Lanzar Vibe amp. ET 13.22@ 106.4MPH Next mods-> Homemade ram air, B&M shifter, Extreme Energy 230/236 cam, Holley Street Dom intake.
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
Remember that the port height is raised on the Vortech heads, and if you add the L98 intake you'll have a huge mismatch that will result in poor airflow into the head.
My guess is that L98/TPI Vortech equipped engines are not very well received as far as performance goes. Scoggin Dickey is coming out with an L98 Vortech/Fastburn inake manifold that should solve this problem. You should be able to utilize these head designs with minimal problems.
It's due in early 2001.
Daniel Burk
http://www.isthq.com/~dan/fcar.html
'84 Trans Am WS6/L69
KB SFC, Moser axles, Torsen Diff. PST suspension, Braided stainless brake lines, Koni struts, 11-inch rear disks,Spohn Adj. torque arm,
Ported 305 heads w/1.94"intake valves, Comp Cams XE262H, Griffen alum. radiator,
Turbine Technologies 2500 stall converter, underdrive pulleys, Crane Hi-6 & more.
1.05g skidpad verified.
New best E/T! 14.039 at 100.82 MPH in 41 degree air at Stanton, Michigan.
Daniel Burk
I've heard that the Vortec heads are not a wise choice for the TPI as for the reasons mentioned above. AFRs, Edelbrocks and such heads are better for the L98 motors
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission with 2.77:1 Rear End
Current Mods: Edelbrock TES 1 5/8" Headers, Hooker 3" Aerochamber Cat-Back System, Performance Resource Chip with 160* Thermostat, Accel Ignition Coil, Cap, Rotor, 8.8mm Wires, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET : 14.32 @ 97.7mph
(corrected for elevation)
Next on the list: LT4 HOT Cam
L98 TPI 350 (5.7L)
Car: 2KGTP
Transmission: 4T65E
Axle/Gears: 2.93
If you guys could read you would see that I am not using a TPI =-0
1986 CAMARO Z28 -> 151,000 original miles, 43,000 on 89' vette 350 block, Holley 650 DP, Weiand intake, 1.6 rockers, 1 5/8" headers, no cat, 2 1/2" Flowmaster catback, Mallory coil, March pulleys, T5 with 3.35 1st gear and 0 miles, 90% Centerforce clutch, 3.73 posi, Eibach 1" drop springs, Spohn LCA's, Spohn adjustable panhard rod, Subframes connectors, polyurethane swaybar bushings/endlinks, 2 12" Sound Streams, 2 Infinity 6X9's, 2 Pioneer 6X9's, 800 watt Lanzar Vibe amp. ET 13.22@ 106.4MPH Next mods-> Homemade ram air, B&M shifter, Extreme Energy 230/236 cam.
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
I have a mag with some dyno tests. They were compareing the L98s and vortecs to the 23* Trick flows. The Vortecs made 16 more horsepower than the L98s. Both were stock heads no porting, the dyno mule was a 350.
Black 90 IROC, L98, A4, 323 gear. SuperRamed 406 in the works!
Grab a pair of Vortec's and an Edelbrock Performer RPM intake made for Vortec's and I guarantee you will be happy with the results for the price you pay. It's a really cost effective way to go fast. You could always do a little porting to unlock even more power
1982 Camaro Z28
trying to make it worthwhile for the spring....
Check the website for progress http://members.fbody.com/Pro82Z/
1982 Camaro Z28
so if its carbed its the tbi? and whats the difference in the two...thanks for any help
currently - 1999 camaro ss - 6spd,hurst,K&N,cutout,nittos
future - 1986 camaro iroc z28- all kinds of goodies
84z96L31vortec
Aug 20, 2017 12:16 AM
L98GTA87
Aug 11, 2015 06:55 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
