Stupid question about roller cams
Old Nov 24, 2003 | 09:28 AM
wiggy'sIROC's Avatar
Car: 1986 IROC
Engine: 305 going to 355
I have a 1970 four bolt 350 block that I am going to build a nice 355 or 383 with. Can I use a "normal" roller cam, or do I ave to use a "retrofit" roller? What is the difference between the two? Would there be a real benefit using a roller over a flat tappet?
THANKS!
Mark
Old Nov 24, 2003 | 09:45 AM
ede's Avatar
ede
guess it depends on what you call normal. to me the 70 block would use the normal roller cam not the piece gm tried to reinvent.
Old Nov 24, 2003 | 10:51 AM
jpk91rs's Avatar
Car: 91 RS, 00 TA Ram Air, 86 IROC
Engine: 305 tbi, LS1, 355
Transmission: 700R4, 4L60E, 700R4 NonLU
You would have to use the retrofit rollercam kit. Being a '70 350 it is not machined for lifter bars and the lifter retainer. Also, the front of the block is not machined for the retainer plate. The GM roller cams have a step on the nose of the cam where the retainer plate goes eliminating the need for a cam button.:rockon:
Old Nov 24, 2003 | 11:04 AM
Car: 1986 IROC
So, that means I would have to use the comp cams "retrofit" that costs $851 for the cam and lifter kit. That's alot of cash! I don't know that it would be worth it in terms of power per dollar over a flat tappet cam. Do you?
Mark
Old Nov 24, 2003 | 11:11 AM
ede's Avatar
ede
doesn't sound much differant than the gm designed piece, but it's been near 2 years since i bought any gm parts
Old Nov 24, 2003 | 11:36 AM
82CamaroZ28's Avatar
Car: 1982 Camaro Z28
Engine: Self-built 350
Transmission: Pro-Built 700r4 w/2800 Vigilante
Axle/Gears: Eaton 3.73 w/Moser axles
FYI, that kit is only ~$673 from Summit:
http://store.summitracing.com/defaul...422-8&x=18&y=9
Old Nov 24, 2003 | 01:53 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
I'd just go with a solid cam and spend that $600-800 on something that'll actually be worth it. The dollar-to-power ratio seems far off in my opinion
junkcltr
Aug 2, 2019 11:12 PM
Cleotiz
Jan 6, 2018 08:56 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
