open/closed heat crossover
Old Nov 24, 2003 | 12:19 PM
Nebu's Avatar
Car: 91' Camaro
Engine: Carbed 305
Transmission: 5-Speed Manual
hi,
i want to install the torquer heads and they say i can use either a felpro 1256 (open) or 1204 (closed) intake gasket.
the metal plate at the felpro is in the middle, but at the original it is on the left. and only at the drivers site intake.
the original gasket is blocked. but what will happen, if i install one with an open crossover?
and why is it closed at all. i think the coolant flows through this?
nebu.
Old Nov 24, 2003 | 11:02 PM
Nebu's Avatar
Car: 91' Camaro
Engine: Carbed 305
Old Nov 25, 2003 | 09:13 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
do u mean the smaller sized rectangular port, smaller than all the others, located right in the middle of the heads? in between the pair of larger rectangular ports? if the gasket has a provision for this smaller port then it would be fine if you wish to remain emissions legal and without a ses light.
ttt
Old Nov 26, 2003 | 11:27 AM
Nebu's Avatar
Car: 91' Camaro
Engine: Carbed 305
the felpro gasket has a metal plate with a little hole in it (or completly closed) in the middle of the head. but the original has a closed port at the left side of the head.
for what is this metal plate good?
nebu.
Old Nov 26, 2003 | 11:31 AM
Car: 1988 IROC-Z
the metal plate is just used as restriction. hence it is called a restricter. i've never used one when replacing the intake gaskets with any ill effects.
Old Nov 26, 2003 | 11:38 AM
Nebu's Avatar
Car: 91' Camaro
Engine: Carbed 305
so i can use the felpro with the open plate in the middle and all will be fine? no overheating problems and such things?
Old Nov 26, 2003 | 11:52 AM
Car: 1988 IROC-Z
it is used for egr purposes only. so no overheating should come from not using the restrictor. anyone else care to comment?
Old Nov 26, 2003 | 12:13 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
I always block those off completely to keep heat out of the intake.
sheachopper
Jul 31, 2019 11:27 AM
gixxer92
May 18, 2017 11:20 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
mfp189
Sep 27, 2015 09:25 AM
