Head gaskets to use with a regular block and aluminum heads???
Old Nov 24, 2003 | 01:36 PM
330hp_91RS's Avatar
Car: 91' RS
Engine: Built 355
Transmission: Probuilt 700r4
I am pretty sure that regular gaskets suffice for installing aluminum heads on a iron block, but I want to make sure. My Dad is having his buddy come to assemble my 355 in the next couple days and he asked me if the Fel-Pro's that came in the Gasket kit will be able to be used.
There aren't any special gaskets needed to mate these two different surfaces are there????
Old Nov 24, 2003 | 02:39 PM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
fel-pro 1003 or 1010 will work
Old Nov 24, 2003 | 07:22 PM
Damon's Avatar
No. Nothing special needed. Just about any compositon-type head gasket will work (Fel Pro, for instance). Some aluminum head manufacturers don't recommend steel-shim type head gaskets but I don't use them regardless.
355tpipickup
Aug 27, 2015 08:13 AM
NinjaNife
Aug 23, 2015 11:49 AM
lakeffect2
Aug 23, 2015 08:44 AM
qz6lwp
Aug 20, 2015 08:10 PM
