IAC?
Old Dec 27, 2000 | 12:59 PM
jmon92conv's Avatar
IAC?
Ok, you all said to check it, but what does it look like and location? I know this sounds stupid, but this is my first TPI motor and am learning as I go along.
Thanks,
Jeremy
92 Z conv
5-spd B&M shifter
home-made ram air, air foil, headers, no cat, TB bypass, kevlar pads, slotted rotors, BMR panhard, alston SFC
when it warms up Edelbrock STB maybe springs
Old Dec 27, 2000 | 02:33 PM
Blade's Avatar
It's right underneath the throtle body below the TPS sensor on the passanger side. It'll have a square four wire connector going into it. I'd say disconnect it, inspect the connector and plug it back in. If you wanna go further, take off the throtle body and clean the IAC.
Old Dec 27, 2000 | 02:39 PM
jmon92conv's Avatar
Thanks Blade
just trying to fix a problem and could not find it in my book
Jeremy
Old Dec 27, 2000 | 10:10 PM
Vader's Avatar
Jmon,
It kinda looks like this:
Later,
Vader
"No matter how hard you try you can't stop us now"
Adobe Acrobat Reader 4.0
Old Dec 28, 2000 | 09:05 AM
jmon92conv's Avatar
Thanks Vader... I will go yo work on it when I can fit it in a nice warm garage.
Jeremy
92 Z conv
5-spd B&M shifter
db057
Jan 10, 2020 08:55 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
thejimsterz28
Sep 30, 2015 08:52 PM
greenyone
Sep 2, 2015 03:39 PM
