Ok, reposting this again....TPI car, runs like crap when cold...no codes....why??
Old Nov 25, 2003 | 11:59 AM
ChrisFormula355's Avatar
Car: Junk
Engine: Junk with nitrous
Transmission: Junk with gears
My iroc almost doesnt' run when its cold, kinda like a carbed car in the winter, but worse, at least in a carbed car you can kinda feather the peddle to make it run OK, but with TPI running like crap when its cold, it just back fires through the intake and weird stuff like that until it warms up. Any ideas??
Old Nov 25, 2003 | 03:03 PM
87350IROC's Avatar
Car: 87' IROC
possibly the ecm, mine did that too, except yours sounds worse
Old Nov 25, 2003 | 05:42 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Coolant temp sensor??
Old Nov 25, 2003 | 06:41 PM
84406's Avatar
Car: 84 Z28
Engine: 355/460hp
Transmission: glide\ford 9"
I see the car is an 85 so the early ecm and the 9th injector for cold start. That is where I would first look.
Old Nov 25, 2003 | 10:09 PM
Vader's Avatar
Is teh running fuel pressure (FPR vacuum connected) at least 34 PSIG? Any less than that, and you'll experience problems in open loop.
Old Nov 26, 2003 | 02:53 AM
rezinn's Avatar
Run better with the MAF disconnected? Or during summer?
midge54
Dec 27, 2019 04:14 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
kyleb24
Aug 15, 2015 08:24 AM
Kaweh
Aug 9, 2015 02:54 PM
