SBC 400 .040 pistons for 3.48 stroke and 5.7 rods
Old Nov 25, 2003 | 06:48 PM
spud's Avatar
Car: 82 & 91 Firebird
Engine: 400 & 355
Transmission: TH350 & 700
Axle/Gears: 4:11 & 2.72
I have been looking for 400 .40 over pistons for 3.48 stroke and 5.7 rods, Does any one know if any piston manufacturesr make this combination.
Old Nov 25, 2003 | 07:03 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Your best bet would be to contact the various piston manufacturers directly.
Old Nov 27, 2003 | 12:25 PM
DTL504's Avatar
Car: 84 Z28 Convertible 2 Seater
Engine: Dart Little-M SBC 400
Transmission: Pro-built Automatics 700R4
Axle/Gears: Strange Engineering 3:73
You might have to get these as custom pistons: try Wiseco, SRP, or J & E Pistons.
Old Nov 27, 2003 | 12:41 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Not too many people are interested in downgrading their 400 that way, so it's not a common combo. You'll almost certainly end up having to get custom pistons, or high-dollar ones like Wiseco, who I believe might offer them off-the-shelf.
Why are you deliberately reducing your engine's power output like that by eliminating 30 cubic inches? Most people most of the time are looking for ways to get more power, not less, which is of course what you're going to get by shrinking your engine size by 7.5%.... about 7.5% less power. You're spending extra money to buy the ammunition to shoot yourself in the foot with.
Old Nov 28, 2003 | 04:47 AM
spud's Avatar
Engine: 400 & 355
Ease of rebuilding, I have a perfect steel, Its not cast 350 crank, and a set of rods, That have been resized, I need pistons and rings, and balanced am I'm ready to rebuild it. And since I'm sure you read the other post, you know my crank from the 400 is toast.
John
Old Nov 28, 2003 | 07:54 AM
DTL504's Avatar
If you have a 400 block why not buy another crank. A Scat 9000 crank can be had for less than $200.00. The money that you are going to spend on custom pistons will exceed the cost of a new crank, plust will will also have more power....
Old Nov 28, 2003 | 07:58 AM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
John
How can it be balanced if you don't have the pistons yet? I would sell the crank & get a 3.75" or 3.875" stroke crank.
Old Nov 28, 2003 | 09:43 AM
spud's Avatar
Engine: 400 & 355
The original pistons were not hurt, when the crank wore down.
Old Nov 28, 2003 | 10:31 AM
Ricktpi's Avatar
Sorry, I thought you were saying it was already balanced.
Old Nov 28, 2003 | 11:18 AM
spud's Avatar
Engine: 400 & 355
Sorry
Rick I missed what you said, When you asked about balanced, What I should have said I would need to get the 377 balanced. And the pistons I refered to, Were the original 400 pistons, for the 408. All I have to do is, get the original crank welded up and then turned down to factory spec and I can use everything I had before.
Sorry
John
Old Nov 28, 2003 | 01:44 PM
five7kid's Avatar
Now you're talkin'.
I can't back up what RB said about a Scat 400 crank for $200, but you might look into that. May cost less than repairing your old one. Then your old one can be used in somebody's 383 project...
Old Nov 28, 2003 | 01:49 PM
DTL504's Avatar
Originally posted by five7kid
Now you're talkin'.
The proof is in the putting:
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2444877143
Hotrodboba400
Dec 10, 2019 07:07 PM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCtometal
Sep 2, 2015 02:01 PM
