What type of tool to disassemble fpr??
Old Dec 27, 2000 | 08:52 AM
I ROCK's Avatar
Car: 89 IROC-Z
Engine: LB9
Transmission: 700-R4
Ok for TPI, the stock fpr has those evil little modified torx bits. I saw the post where Pat went through hell with them and was just wondering what the correct tool to use on them is, or should I not take them out b/c they will break? I was just going to shim the fpr until I have the spare $$$ for an afpr so any advice is appreciated.
89 Iroc-Z LB9 305 TPI auto 2.73 posi:
3" Dynomax "cat" back,K&N filters, TB bypass, 3" pipe in place of cat, cleaned and flow-matched injectors, 170' thermo, mild ignition mods, synthetic oil, kicker sound system, soon to have 3.73 posi...
Old Dec 27, 2000 | 10:00 AM
Blade's Avatar
If I remember correctly, it's a T-10 torx security bit you'll need.
92 Z28 L98 350
Ported stock heads, XR270HR-10 cam, TES headers, Crane AFPR, Flowmaster catback, MSD ignition components.
Best ET 13.5@105 mph
"Take that auto, drop it in first, hold the brakes, stomp the gas and grin from ear to ear! :-)
Click here to see my car at Truspeed.org
Check out TruSpeed at http://www.truspeed.org
Check out the Bin Archive at http://www.truspeed.org/bins.html
Old Dec 28, 2000 | 07:03 AM
Pat Hall's Avatar
The bolts I broke were the TPS mounting bolts on my old TBI unit. The ones on your FPR should come undone without too much trouble. You do need a special torx bit though. They put a little tit right in the middle of the torx head so you can't use a regular torx bit. I don't know how hard it is to find the security torx bits at your local parts store, but I know I got one with my adjustable regulator from TPIS. You could probably buy just the bit from them if you contacted them and asked. The bit that came with my AFPR has the initials "TPIS" stamped in the side of it. Also, I do know that Snap On sells these bits. My old boss at the shop I used to work at had a set of them from Snap On. Hope this helps.
89RS w/350 TPI; 69RS/SS w/450 HP 350/Muncie 4-Speed "Too weird to live, too rare to die."
Old Dec 28, 2000 | 11:34 AM
I ROCK's Avatar
Car: 89 IROC-Z
Engine: LB9
Thanks guys.
3" Dynomax "cat" back,K&N filters, TB bypass, 3" pipe in place of cat, cleaned and flow-matched injectors, 180' thermo, mild ignition mods, synthetic oil, kicker sound system, soon to attempt engine swap...
Old Dec 28, 2000 | 06:24 PM
Vader's Avatar
Originally posted by I ROCK:
Ok for TPI, the stock fpr has those evil little modified torx bits...and was just wondering what the correct tool to use on them is, or should I not take them out b/c they will break? I was just going to shim the fpr until I have the spare $$$ for an afpr so any advice is appreciated.
U ROCK,
Why would you go to all that trouble and not convert to an adjustable FPR? The easy instructions are in this file:
AFPR.pdf
The cost of conversion is about 55¢, and if you have enough cash for the $30.00 intake gasket set, the extra 55¢ shouldn't break you.
Later,
Vader
"No matter how hard you try you can't stop us now"
Adobe Acrobat Reader 4.0
[This message has been edited by Vader (edited December 28, 2000).]
Old Dec 28, 2000 | 07:52 PM
I ROCK's Avatar
Car: 89 IROC-Z
Engine: LB9
well I don't have a brazing rod and my goal is to drive the car soon...since it's been three weeks. Thanks for the file I remember seeing it before. When the weather gets a little warmer I'm definitely doing it. I doubt I'll have the car at WOT until spring anyway...
InfernalVortex
Apr 20, 2021 11:31 AM
Rocket-Doc
Nov 14, 2015 02:08 PM
Reid Fleming
Oct 10, 2015 09:56 PM
bjpotter
Oct 4, 2015 07:48 PM
Lmancha96
Sep 25, 2015 08:11 PM
