engine removal question
Old Nov 26, 2003 | 04:14 PM
irocfreak's Avatar
Car: 1986 Iroc-z
Engine: Soon to be 350
Transmission: 700junk4
My motor is almost ready to be taken out. My problem is the bolts that hold the tranny to the motor. My question is, are there only four bolts that hold the two together. If so i have gotten the lowest one on each side out but i am having problems getting to the upper ones. Is there any special tricks or tools to do so. Oh, yeah almost forgot, its an 86 305 tpi with an 86 700r4.
Old Nov 26, 2003 | 06:58 PM
hydric's Avatar
Car: 1985 Iroc-z
Engine: 355 sbc
well slick, theres a bit more than u think...
there are 3, yes 3 torqu converter bolts, 15mm are the size... you will need to remove them...
there are i think 6 bellhousing bolts, 9/16 i think.. there are two up top, i suggest long extensions with a swivel end on a 3/8 ratchet... i've heard people bending wrenches and using them as well, once u crack them loose, they are usually finger loose..
u can feel them with your fingers
Old Nov 26, 2003 | 07:46 PM
irocfreak's Avatar
Car: 1986 Iroc-z
i already did the torque converter bolts and thanks for the heads up on how many bolts are on the bell housing
Old Nov 26, 2003 | 09:09 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It's a whole lot easier to get to the top 2 bell housing bolts with a box end wrench, from above.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Aug 16, 2015 11:40 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
3rdgenparts
Aug 8, 2015 07:09 PM
