I dont have AC anymore, how can I bypass my heater valve?
Old Dec 29, 2000 | 11:01 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
? Thanks 350 TPI (89)
Old Dec 29, 2000 | 11:34 AM
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
Is there a problem with your valve? My opinion is to leave it there. In the summer hot water will still flow through your heater core. This can creat extra heat under the dash which is not good considering the air box resides close to the ecm. Secondly I do not know if the heater core can take hot weather pressure. It seems like replacing a heater core is a common operation in our thirdgens. Any additional strain that can be avoided could save you some headaches in the long run. Just my .02$
91 Formula 305 TPI Stock
88 Formula 350 TPI Stock
Old Dec 29, 2000 | 05:10 PM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
What about getting rid of the heater core and box? Can you? Do you drive in weather two cold to live without it? My heater doesn't work, and I want to get rid of it. It's not hooked up at all. But I live in CA, so I can. There will be alot more room also.
'82 Firebird, dead stock, 9 bolt disc rear, over 200,000 miles and still going strong, more to come...
Bubbajones_ya
Jul 6, 2024 08:32 PM
TX-SleeperC5
Feb 24, 2016 01:34 PM
bbsr72
Sep 27, 2015 05:55 AM
355tpipickup
Sep 13, 2015 11:35 PM
buckshot63
Sep 10, 2015 09:15 AM
