a couple rebuild kit questions
Car: '84 Z28
Transmission: th2004r
i'm rebuilding an 87 350 truck block. i'm thinking of getting a kit from northern auto parts for $150+ upgrades.
its for an 81-85 block but i'm going to be putting heads and an intake from an older block on. would that work? i know i'd have ot get a 1 peice rear seal and a oil pan gasket for a later block but would anything else be different?
also, would it be worth the few extra bucks to get molly rings? what do molly rings do? what about clevite bearings? are they better than federal mogul?
here is the page its at,
http://www.northernautoparts.com/Pro...uctModelId=712
Car: 1989 C4
Axle/Gears: 307
A typical rubber oil pan gasket is reusable, look for cracks and rips if its clean re-use it save $35 bucks. I re-used my gasket at least a dozen times with no leaks until last time when it ripped. A bearing upgrade and ring upgrade just depends on what you want from the engine or how heavy your wallet is.
Car: 92Z28
Transmission: A4
The rings and bearing are better. The moly rings will have less friction and cylinder wall wear. The bearings are coated so they are less likely to fry at a SHORT loss of oil pressure.
Car: 1989 C4
Axle/Gears: 307
Originally posted by TheViper
thanks, so the only things i would need for it to work is the RMS and the oil pan gasket?
hectre13
Dec 11, 2023 08:14 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
