Identifying engine block - 350 vs. 305
Old Nov 27, 2003 | 09:59 PM
Chris90Formula's Avatar
I'm about to purchase a used 350 from someone. How can I be sure that it is a 350 and not a 305. The engine will be assembled with intake and exhaust manifolds so I won't be able to see the engine bore. It has a "57LG" on the back left of the block. I thought that signified a 5.7 liter, but after reading some old posts it seems that some people have had 305's with that stamp. The engine is out of a 88 IROC TPI.
thanks,
Chris
Old Nov 27, 2003 | 10:49 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
If it says 5.7LG it's a 350. If it came from an 88 it should also be stamped on the front side of the engine 5.7 or 350. Whats the casting number?
Old Nov 27, 2003 | 10:51 PM
The casting number on the right rear side is 4093638.
Old Nov 27, 2003 | 11:05 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
Are you sure there's not a 1 in front of that number??
if so, then:
14093638...350...87-95...2 or 4...Roller or flat tappet cam
which would make sense for an '88 Iroc with a 5.7L.
Old Nov 27, 2003 | 11:26 PM
TekViper's Avatar
Car: 1990 Pontiac Firebird
Engine: 3.1L v6
Transmission: Automatic
do 305 and 350's have the same stroke? if they didnt couldnt u drop a long stick into the cylidner and measure the stroke?
Old Nov 27, 2003 | 11:43 PM
gen3z's Avatar
Car: '92 droptop bird
Engine: 5.7L,mild cam etc.
Transmission: modded 700r4 w/2600
same stroke diff. bore 3.75bore-4"bore....
Old Nov 28, 2003 | 11:12 AM
TekViper's Avatar
Engine: 3.1L v6
doh
Frozer!!!
Jan 19, 2024 04:55 PM
jhawkeye
May 25, 2022 06:33 PM
theshackle
Mar 5, 2017 06:37 PM
lakeffect2
Aug 23, 2015 08:44 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
