Diff between Tappet and Roller lifter springs
Old Nov 28, 2003 | 10:07 PM
CamaroFreak87's Avatar
Car: 1987 Camaro IROC Z-28
What's the difference between springs made for a flat tappet cam and springs made for a roller cam? I see ProAction heads forsale on ebay and stuff and they advertise upto .600" lift springs but not for roller cams. I'm just wondering what the difference is. I have a cam with about .515" lift, but it's a hydraulic roller cam. Thanks.
Ryan
Old Nov 29, 2003 | 05:59 AM
ede's Avatar
ede
differant cams have differant requirements as far as springs go. few of the factors about selecting a spring is diameter, seat preasure, open preasure, installed height, and coil bind height. for what ever cam you run you need a spring to meet the requirements to keep the valve closed and return it to rest when not on the opening side of the cam. rollers as far as i know always require more/bigger/stronger springs. i'd buy a set of springs from comp, lunati, or crane and trash anyone and everyone elses springs. i'd especially be careful of gm, k motion, and any springs installed on a set of heads of unknown makers or quality.
Old Nov 29, 2003 | 07:22 AM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
Roller springs are able to handle the quicker snap of the ramps of the roller cam. The lobes on a roller cam have faster ramps.
Brian Felts
Old Nov 29, 2003 | 10:27 AM
Vader's Avatar
Yes, a roller valve train should be able to handle that. However, that is rather odd in the face of what springs the factory used on SBC engines (and still does) all the way through the LT1s and Vortec 5.7 (still available through 2003 in full size vans). They are the same old 85#, 1.25" springs that Chevy used in 1955 - flat tappet or roller.
sandman92084
Sep 12, 2015 10:27 PM
Mr. Chevy
Sep 11, 2015 06:06 PM
carattini
Sep 10, 2015 07:46 AM
dimented24x7
Sep 6, 2015 03:51 PM
rudolphschenker
Sep 4, 2015 02:41 AM
