picture of 3 wire o2 hooked up
Old Nov 28, 2003 | 02:42 PM
1990GTA's Avatar
Car: 1990 GTA
Engine: 5.7 T.P.I.
Axle/Gears: 3:23
Does anyone have a picture of where the 12v is hooked up? I did a search and found a lot of info, but I would like to see a picture of how it is hooked into the fuel pump relay. I am ready to install it, and I dont want to screw it up. I have three relays in a row, is it the middle one? Even a good drawing would help.
Old Nov 28, 2003 | 06:39 PM
91B2L's Avatar
Car: 1991 Z-28
Transmission: TH700
Your right about it being the middle relay. I connected mine to the grey wire when I was running a heated O2 sensor. I've read where you need one if you have headers, but after driving with it for several months, I decided to replace it with a regular one wire O2 sensor. I really didn't see any difference in performance. I know it is suppose to get the engine in closed-loop faster, that's just me. Best bet is to double check it with a voltmeter.
Old Nov 28, 2003 | 08:56 PM
1990GTA's Avatar
Car: 1990 GTA
Engine: 5.7 T.P.I.
Axle/Gears: 3:23
91B2L, do you have headers? I have long tubes, and the car is running terribly rich.
Old Nov 29, 2003 | 10:43 AM
91B2L's Avatar
Car: 1991 Z-28
Transmission: TH700
I'm running Edelbrock headers. A month after I installed the headers, I got a code 44, I think that's running rich. I went both ways to cure the problem. First, I got a Holley adjustable fuel pressure regulator and second, the three wire O2 sensor. Not sure which one cured it? Most likely the afpr helped out more. Sorry, not much help.
gta892000
Aug 11, 2019 11:16 AM
Gordonr1973
Sep 29, 2015 11:59 AM
tattmann
Sep 27, 2015 05:20 PM
wstephan96
Sep 25, 2015 04:28 PM
gta892000
Sep 16, 2015 12:37 AM
