Lifter/Rocker/Pushrod Break-In
Old Nov 29, 2003 | 09:52 AM
demonkey36's Avatar
Car: 1991 Camaro RS
Engine: Was 305 LO3 TBI, now carbed 355
When putting all those in, do I need to use the Comp Pro Cam Lube or whatever? Or is there just something generic that I can use? And if there is something generic, will it be better to use the Comp stuff?
Old Nov 30, 2003 | 05:08 AM
PLANT PROTECTION's Avatar
Car: 1987 Monte Carlo SS
Transmission: 200-4R
Axle/Gears: 7.625 10 bolt/3.73s
If it is the 91 in your info, the roller cam won't need anything special. Soak the lifters in oil and make sure the contact points of the rockers have a bit of oil.
Old Nov 30, 2003 | 07:12 AM
ede's Avatar
ede
i use moly lube on anything like a lifter to cam or rocker to ball and lubriplate 105 on everything else. i'm out of moly now and may just start using the lubriplate on everything.
Old Nov 30, 2003 | 08:28 AM
demonkey36's Avatar
Car: 1991 Camaro RS
it's actually a brand new 350 going in....does that change anything?
Old Dec 1, 2003 | 08:23 PM
demonkey36's Avatar
Car: 1991 Camaro RS
aaaanyone?
Old Dec 1, 2003 | 10:01 PM
a73camaro's Avatar
Cam lube goes on the cam lobes and the "bottom" of the lifters. Prime the engine with the correct type of primer and rotate the crankshaft during the priming operation.
This will get oil on all the valve train gear.
Then do the 2000-2500 RPM for 20 minutes to break in the cam.
That is all
PS The factory doesn't even to this. They fill it with oil and run it.
Old Dec 1, 2003 | 10:49 PM
demonkey36's Avatar
Car: 1991 Camaro RS
so nothing needs to go on rockers/pushrods/etc.? just prime it?
pr1689
Jan 6, 2008 07:42 PM
MikeDirntRulez
Jun 10, 2006 09:19 PM
zz17iroc
Nov 10, 2005 07:34 AM
PhLaXuS
Car Audio
Sep 21, 2005 08:14 PM
