timing chain change without dropping oilpan
Old Nov 29, 2003 | 03:03 PM
Nebu's Avatar
Car: 91' Camaro
Engine: Carbed 305
Transmission: 5-Speed Manual
hi,
is there a way, where i dont need to drop the oilpan during the timing chain installation?
nebu
Old Nov 29, 2003 | 03:13 PM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
it is possible, just expect an oil leak when you're done.
Old Nov 29, 2003 | 07:33 PM
Paul Riccioli Jr's Avatar
Car: 89 IROC-Z
Engine: 383
You don't have to drop the pan entirely.....just loosen all the bolts so it drops down about a half inch. This is the only way to do it correctly and hopefully have no leaks when you're done.
Old Nov 29, 2003 | 08:32 PM
Nebu's Avatar
Car: 91' Camaro
Engine: Carbed 305
and i dont need a new gasket? i mean, i cant put a new one on if the bolts are still there
Old Nov 29, 2003 | 10:11 PM
Vader's Avatar
And you won't need a new gasket. A little cleanup of the excess oil and a small bead of RTV couldn't hurt, especially since you'll be applying a little to the ends of the TC seal anyway. Don't get happy with the pan bolt torque either, or you WILL have a leak.
Old Nov 30, 2003 | 08:30 AM
ede's Avatar
ede
triming the lip off the back of the timing cover will help a bit on the reinstall. if you remove it entirely would eliminate the need to drop the pan if you do it a second time, but what's the odds of doing a timing chain twice?
Vintageracer
Jan 10, 2020 05:33 PM
maroe624
Apr 16, 2017 08:29 AM
jharrison5
Aug 19, 2015 05:53 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
MY87LT
Aug 17, 2015 08:43 AM
