NOT GOOD I THINK MY BALANCER IS SCREWED
Old Dec 29, 2000 | 10:44 PM
MARKT111's Avatar
Car: 1989 TTA
Engine: 3.8 Turbo
Transmission: 200R4
I was under my car today looking for an antifreeze leek and found something I thought was much worse,I had the car running so their was pressure and noticed the balancer looked like it was wobbling.Could this be caused from the first owner installing pulleys and not torking them properly?what is a good replacement street/strip balancer without spending a mint?is this fairly common?I never saw it before
89 FORMULA 350,WS6 SUSPENSION,FRESH 355 MOTOR,TCI 12" STREETFIGHTER,TRANSGO SHIFT KIT,3.70 GEARS,SLP REAR CONTROL ARMS/PANHARD,HOTCHKIS STB,FORMULA GP'S,FLOWMASTER EXHAUAST,58 MM BBK,MINIRAM INTAKE,ALL FREE MODS(HEADERS WAITING IN GARAGE)SLP 3/4",NO CATS,
Old Dec 29, 2000 | 11:09 PM
MikeC.86Roc's Avatar
Could be that he jacked the motor up at one time by using the harmonic balancer .. No, I would not say that its common either. In fact, its not good at all if the balacer is wobbling because it will cause premature bearing wear. I would check the pully first to make sure its not bent and then take a look at the damper. Does it look like the original? If so then its probably time for a replacement anyways, the old rubber torsional dampers will develop stress cracks in the rubber and this might be the wobble you are observing. I have a streetdampr (less expensive version of the fluidampr, just not SFI approved and who cares) and it was only 160$ for internal balance and I think the external is 210$. Hope this helps a little.
Old Dec 30, 2000 | 01:42 AM
MRZ28HO's Avatar
Car: was: 1984 Camaro Z28
Engine: was: L69
Transmission: was: 700-R4
Yup, not good at all (if it is the balancer and not the pulley itself). If you want inexpensive, pick up a GM Performance Parts 6-3/4" diameter damper (cost -$90 from PAW) for internally balanced SBC engines. I have one and it is t!ts.
George P. Lara
Z28s Owned:
1984 "L69" A4
1994 LT1 M6
Member: SCCA, SCFB, SC3GFB
Camaro Info: MadMike's
Old Dec 30, 2000 | 03:04 PM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
I've got a used one I'll sell ya real cheap. It's in my garage sitting there doing nothing and it is good. Only reason it got replaced was for another problem I was troubleshooting. It's a stock one off an L98 (350)
KAM
Old Dec 31, 2000 | 11:32 AM
MARKT111's Avatar
Car: 1989 TTA
Engine: 3.8 Turbo
Transmission: 200R4
thanks for the replies,it's definately the damper not the pulley,I want to upgrade when I replace it because I spin the motor higher than stock now and am planning on doing a cam and heads when the tax money comes back,want to know which one I shoukld use
italiano67
Dec 11, 2016 09:21 AM
camaro71633
Sep 1, 2015 10:24 AM
InfinityShade
Aug 22, 2015 08:00 PM
TheJoeY88
Aug 13, 2015 06:51 PM
blacksunshine'91
Interior Parts Wanted
Aug 10, 2015 12:04 AM
