timing survey
Old Nov 30, 2003 | 12:47 PM
daverr's Avatar
timing survey
im curious to know how much total timing advance u guys are running on your non-stock engines?
dave
Old Nov 30, 2003 | 03:54 PM
ede's Avatar
ede
36 and 38, wouldn't the info be more relivent if you ask what the engine combo was too?
Old Nov 30, 2003 | 06:10 PM
ronterry's Avatar
Car: '94 Corvette
Yea, 36-38 with natural aspiration. I run mine on the high side, and probably could get away with 40° at my altitude (6300ft).
Don't forget fuel octane/additives/types have major affects on burn timing.
Ron
Old Nov 30, 2003 | 08:32 PM
daverr's Avatar
36 to 38 degrees seems to be the most common.i wanted to see if someone was running timing outside of 36-38 degrees.let me elaborate on the "nonstock engine" a na motor that have aftermarket heads,cams(more duration),higher or lower compression etc
dave
Old Dec 1, 2003 | 02:18 AM
ronterry's Avatar
Car: '94 Corvette
The only real way to find out your total for you is to start at 36° and start adding it till it pings. Normally higher compression you'll need slower burning fuel (i.e. higher octane) to keep from pinging at 36° at WOT.
Anything that cranks up combustion temperatures speeds up the burn, and you'll have to close the gap between ignition & TDC.(i.e. retard the timing)
I never seen cams make much of a difference in combustion temps, but head material, & compression do.
Aluminum draws heat out of the combustion chamber faster than iron, so aluminum lowers the temp.
Engine load affects temps a lot also; in fact you can get away with a lot more than 36° when just cruising under light throttle. (i.e. computer advance or vacuum advance)
Hope that helps a little...
Ron
Old Dec 1, 2003 | 04:12 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
32 to 36 depending..........
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
