Sounds Like Metal Rubbing...
Old Dec 1, 2003 | 03:15 AM
Black IROC 86's Avatar
Car: 1986 IROC Z
Yesterday night I drove out to my brothers house in L.A which is about 15-20 minutes from here. I was parking my car in front of his house and as I was going Reverse I hear this Noise kinda sounded like metal touching or rubbing coming from the right back end of my car. It was wierd cuz i never heard this before. I chilled there for about 3 hours then i went home. The drive home was fine, But as i got to the front of my house there it goes again, it feels as if it comes after 20 minutes of driving and when i Reverse and Also when i turn slightly, like when im parking. I got no idea what this problem is. It also does it as i go foward slowly. Any Help? Somone suggested to check my U-Joints.
Sorry If This was in the wrong section, couldnt find where to put it.
Old Dec 1, 2003 | 04:46 AM
ede's Avatar
ede
someone has a good idea, check your u joints
Old Dec 1, 2003 | 04:58 PM
MYBLUZ's Avatar
Car: 1991 Z28 1LE A.K.A The blue rocket
Engine: Blown 383
Transmission: Full manual 700R4
If your car is a posi, you might look at the locker in your rear end. Mine made simulair noises one time when I changed the fluid and didnt add any limited slip additive.
Old Dec 2, 2003 | 02:20 AM
87Formula356's Avatar
Car: 87 Formula Firebird
Engine: 5.8Ltr 356
Transmission: WC t-5...... probobly go boom soon.
limited slip additive??? oh ****, i prob should have put that in mine when i changed the fluid right? ill have to do that, by the way, does anyone reccomend a certain type of synthetic rear end fluid?
Old Dec 2, 2003 | 04:45 AM
ede's Avatar
ede
m1 or amsoil and gm posi additive
Old Dec 14, 2003 | 08:37 AM
CALIROCZ28's Avatar
Car: '98 Z28 LS1
Transmission: 4l60E
Axle/Gears: 373
Have you looked under your car for any obstructions in your drivetrain? I had a similar incident which I found was my emergency brake cable had come loose from the metal tab that holds it up and out of the way of the driveshaft. The noise was similar to what you described. It was only noticiable when backing up or when moving very slowly going forward.
db057
Jan 10, 2020 08:55 PM
86White_T/A305
Mar 6, 2016 01:48 PM
LittleFranks
Oct 7, 2015 11:26 PM
ccop
Convertibles
Sep 14, 2015 04:13 PM
Blue419
Sep 10, 2015 01:03 PM
