Click Sound when Connecting Battery
Old Dec 1, 2003 | 12:59 PM
GTA88's Avatar
Whenever I disconnect or connect the battery cable, I hear a click from the passenger side front corner. Is this normal ? I have a battery drain I am trying to track down. The click doesn't happen when I connect the battery to my test light and complete the circuit that way. It only happens with the cable being directly on the battery terminal.
I thought maybe the click was some relay or solenoid or something energizing. Is this click sound supposed to happen, or is this maybe the source of my battery drain ?
In case my sig doesn't show, the car is an 88 GTA 5.7 TPI.
Old Dec 1, 2003 | 01:05 PM
ede's Avatar
ede
most likely it's normal, but you ought to track it down to be sure
Old Dec 1, 2003 | 01:12 PM
MNformula350's Avatar
My formula does the same thing whenever i connect or disconnect the battery.
Old Dec 1, 2003 | 07:30 PM
d_johnsen's Avatar
Car: 1989 Firebird
Axle/Gears: ?
a clicking sound would most likely be a relay energizing
BRoss99
Aug 10, 2025 05:08 PM
GTAman
Mar 15, 2019 11:40 AM
B_Dubya
Aug 26, 2015 05:09 PM
justin57
Aug 20, 2015 07:05 PM
