Head Gasket leak?
Old Dec 31, 2000 | 04:43 PM
Mike '91 Z28's Avatar
Head Gasket leak?
Okay I just got done torquing down my new heads and I seem to notice after I rotate the engine that there is a hissing noise. It kind of sounds like the piston is sucking in air. I can't make out where and which cylinder but is this normal after installing new heads and gaskets?
Old Dec 31, 2000 | 06:15 PM
I ROCK's Avatar
Car: 89 IROC-Z
Engine: LB9
Transmission: 700-R4
are the plugs out?
89 Iroc-Z LB9 305 TPI auto 2.73 posi:
3" Dynomax "cat" back,K&N filters, TB bypass, 3" pipe in place of cat, cleaned and flow-matched injectors, 180' thermo, mild ignition mods, synthetic oil, kicker sound system, soon to attempt engine swap...
Old Dec 31, 2000 | 06:30 PM
Nope, all plugs are torqued down to spec. Could it be that the air is just being sucked through the valves (I havn't put the rocker arms on yet)? I didn't here this hissing noise when i rotated the motor with the old heads/gaskets.
Old Dec 31, 2000 | 08:23 PM
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
Try some mild soapy water around the head gaskets and check for bubbles. To check if the valves are sealing take some wide thin making tape and tape over the ports. If there is a seal problem you will see the tape move. I am assuming that you have the rockers and intake off. I would do one cyl at a time with all pulgs out except the cyl you are testing. Also rotate both directions.
Old Dec 31, 2000 | 08:58 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Its probably air pushing past the rings. Its normal. If you are sure the gasket is on right, don't worry about it.
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey, 22# injectors,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Old Dec 31, 2000 | 10:15 PM
I'm pretty sure I put the gaskets and torqued the heads down(in the correct order) correctly. I'm probably just paranoid and just worrying too much. Anyways, thanks guys for your info.
Old Jan 1, 2001 | 01:55 PM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
Yep, I agree that it's normal. If you are relatively confident that you installed the heads correctly, what you're hearing is air escaping past the rings on the compression stroke. This is perfectly normal.
Anyone's who's changed bearings with the engine in the car will recognize that hissing sound when the engine is turned over by hand in order to reach the different bearings.
Hope this reassures you.
Jake
1986 Corvette Coupe, 415 CID, Edelbrock 6073s, ZZ9
355tpipickup
Aug 27, 2015 08:13 AM
NinjaNife
Aug 23, 2015 11:49 AM
qz6lwp
Aug 20, 2015 08:10 PM
