Short Quick Head Question Please!
Old Dec 1, 2003 | 04:11 PM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
I have some 305 heads from an 89 L03
Can I put them on my pre-86 305?
Old Dec 1, 2003 | 10:01 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Not if you don't like getting slapped...
Okay, they will bolt to the block, but the intake bolt angles on the center bolts will be different. The rockers have to follow the heads, but the pushrods need to be of the type for the block (lifters, technically). The valve covers will be different (no biggie, they follow the heads, too).
Why, oh why, are you considering this abomination?
Old Dec 1, 2003 | 11:21 PM
Kingtal0n's Avatar
Transmission: 4l80e
Axle/Gears: 3.512
because the motor needs to get running asap its going to be towed and all i have is L03 heads for it.
So i will also need to use the rockers that were on the L03 heads but not the lifters / pushrods those stay in the motor?
Well it makes sense since they are hydralic roller and the other motor is not.
thanks five7 once again ill do the swap tommarow
Old Dec 1, 2003 | 11:35 PM
Vader's Avatar
You should be able to use the long push rods (from the '86) and SA rocker arms (from the '89) and make it work.
You'll probably have to use the '89 intake or elongate the center two holes on the '86 intake.
NinjaNife
Aug 23, 2015 11:49 AM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
BBSDesigns
Aug 11, 2015 07:39 PM
