starter and flexplate different?
Old Dec 3, 2003 | 02:35 PM
TheViper's Avatar
Car: '84 Z28
Transmission: th2004r
i have an 87 350 i'm going to be putting in in place of an old 283. could i use the same starter i have on the 283 on the 350?
does the 87 350 have the bigger flexplate?
Old Dec 3, 2003 | 04:04 PM
Damon's Avatar
The flywheel on a later model 350 is the smaller 153 tooth flywheel/flexplate. Is the bolt pattern on the later model starter the same as your 283 block? Not sure.
Old Dec 3, 2003 | 05:42 PM
TheViper's Avatar
Car: '84 Z28
do you think it will cause any header clearance issues?
Old Dec 4, 2003 | 05:08 AM
ede's Avatar
ede
only 2 bolt patterns on sbc starters, straight and angled. doesn't take anything more than a quick look to see what you have
Old Dec 4, 2003 | 03:57 PM
TheViper's Avatar
Car: '84 Z28
the 350 is angled, would the 283 be angled or straight? i forgot what it was.
Old Dec 5, 2003 | 10:04 AM
Damon's Avatar
That's sorta the "gotcha" looking at early vs. late engines. Even though the later 305s/350s often used the smaller 153 tooth flexplate/flywheel they had a starter that used the staggered bolt pattern.
On EARLY engines it was a simple relationship..... 153 tooth = straight bolt pattern starter; 168 tooth = staggered bolt pattern.
With the later engines this gets muddy. The thing that MIGHT save you here is that the 283 might be dual-patterend (drilled for both stright and staggered starter bolt patterns) in which case you bolt on a 153 tooth flywheel/flexplate and the starter off the later motor and away you go. MAYBE. If not, you're going to end up buying a new starter.
3rd gen money
Oct 11, 2019 09:57 PM
Gunner242
Dec 25, 2015 04:49 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
Jlanz55
Sep 29, 2015 08:55 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
