Good Hot Rod article on torque & HP
Old Dec 4, 2003 | 04:46 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Jan 2004 issue. Talks about what each is, how they are measured, what each does, and what to shoot for.
The old "short stroke/big bore small displacement faster than longer stroke/same bore" debate is put to bed. Some discussion on stroke vs. bore to obtain a certain displacement, and merits of each.
The article doesn't appear to be on line yet. If you don't subscribe, it's worth the newsstand price of the mag just for that article.
So, when this topic comes up in the future, all answers have to be consistent with the info in this article, or the person posting counter-claims will be cyberslapped...
(After you read the article, you might better understand the reasons GM went with the 305, even though they don't discuss that directly, and, even if you still don't agree with GM's decision...)
Old Dec 4, 2003 | 05:43 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
sounds interstin, i'll havta check it out.. maybe someone can scan it n post it up for everyone
Old Dec 4, 2003 | 06:11 PM
bes217's Avatar
Yep, my new issue just came in the mail yesterday. Let me scan the article real quick.
Old Dec 4, 2003 | 06:53 PM
bes217's Avatar
Hot Rod Horsepower article
You are going to have to save the pictures or copy them into adobe or something and zoom in on them because they are not quite big enough to read the writing. Sorry.
Old Dec 7, 2003 | 02:59 AM
377ciTT's Avatar
Car: 94z28,84 3rdgen no engine,64 vette
Engine: lt1,-,350
Transmission: t56,-,m4
looks like i need glasses cant read the scans i opened them up in ap 7.0 no good all well maybe ill ust buy the mag or read it at the bookstore thank you htough
Old Dec 8, 2003 | 01:23 AM
jrg77's Avatar
Car: '85 Camaro
Engine: LG4 305
Bought the mag and read the article. A lot of focus was spent on performance in rpm range. So what determines an rpm range? How much difference is there between a street rpm range, a street/strip rpm range, and a strip only rpm range? I understand that various parts can only flow so many cfm, but how does that relate to the rpm range? Also how does the cam affect the range? How broad a range can one have?
They also said in the article there is no way to make big power on a small block without a supercharger or nitrous. So how much more does a big block weigh than a small block with a supercharger? Power to weight is an important factor also, right?
If you use a supercharger and a high rpm cam can you use the supercharger to bring back the torque lost on the bottom?
specialized
Jun 18, 2022 09:26 AM
xbmx89
South Central Region
Oct 31, 2015 10:59 AM
InfinityShade
Aug 22, 2015 08:00 PM
ezobens
Aug 19, 2015 10:29 PM
gwade12
Aug 8, 2015 08:17 AM
