coolant and washer fluid bottles
Old Dec 5, 2003 | 02:27 AM
1fast91rs's Avatar
Car: 1991 RS
Engine: 305 LO3(TBI)
Transmission: TH-700R4
i need to buy a new coolant and washer fluid bottle for my 1991 rs and i was wondering if anyone could tell me what the part numbers are for them?
Old Dec 5, 2003 | 05:55 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Do you still have the originals? If so, the part numbers are on them.
Old Dec 5, 2003 | 06:32 AM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
There won't be part number on the originals, only casting numbers. Coolant tank is 10170175, Washer Resevoir 22063426.
Old Dec 6, 2003 | 09:46 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
There was on both of my coolant bottles on the birds.
Old Dec 6, 2003 | 10:40 AM
Vader's Avatar
My Pontiac uses the 14070997 as the coolant reservoir, and the 10035811 as the washer solvent container. Both of those "casting" numbers are still valid in the dealer parts system, and are molded right into the blow-molded bottles. the washer reservoir is $14.80 and the coolant reservoir is $11.70.
Old Dec 6, 2003 | 10:26 PM
25THRSS's Avatar
Are these the same for the 1992 model year as well?
Old Dec 7, 2003 | 12:52 AM
joshwilson3's Avatar
Old Dec 7, 2003 | 12:56 AM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
Even if the numbers on the tanks aren't right, I bet if you were to give those numbers to your GM dealer, they would cross......
sheachopper
Jul 31, 2019 11:27 AM
mfp189
Sep 27, 2015 09:25 AM
