Code 34
Old Dec 6, 2003 | 02:05 PM
89 305 Formula's Avatar
Code 34
I have a 89 305 TBI formula, and the check engine light comes on when im driving, checked code and its 34, not sure what that is. It goes away when i shut the car off and start it again, any help would be great. Thanx
Old Dec 6, 2003 | 02:10 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
From the Board FAQ:
"34. Low voltage (high vacuum) at mass air flow sensor (or MAP sensor)"
Old Dec 6, 2003 | 02:28 PM
Fairly Strange's Avatar
Car: '89 Formula
Engine: 305 TBI
Does this show any symptoms?
Just curious, as I get a "34"....but no "service engine" light unless the motor is shut down.
I DO have symptoms, though......
Rough idle and or engine shut-down once "closed loop" is attained. Runs fine after a rather difficult re-start.
Old Dec 6, 2003 | 02:31 PM
How would i be able to check if that is really the problem, what kind of diagnositics is there. can someone post up the service manual procdure on how to fix it.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
