IAC gasket
Car: 85 Iroc-Z
Axle/Gears: 10-bolt 3.42
IAC gasket
is it possible to buy just the gasket for the iac valve? i butchered mine when i took it apart to clean/lubricate it. also, if it is available, does anyone have the gm part number for it?
thanks
thanks
I know the FelPro intake set doesn't include that gasket, and there is no TB repair gasket set that I'm aware of. A dealer may be your best chance.
As an alternative, you could get a roll of heavy gasket paper and cut your own.
non sense!! they sell a whole damn tbi gasket kit at advanced auto, just ask em to check for a bit, has every gasket on and in the tbi
you can just use some rtv sealant on that sucker if you want though, and DONT over tighten the iac. i did and it broke off in the tbi, took me two hours tring to get out the broken off stub in the threads.......
you can just use some rtv sealant on that sucker if you want though, and DONT over tighten the iac. i did and it broke off in the tbi, took me two hours tring to get out the broken off stub in the threads....... Joined: Feb 2004
Car: 89 GTA
Engine: 6.0L Procharged
Axle/Gears: 4.10
Re: IAC gasket
Updating old thread:
You can buy the IAC gasket
AC Delco 40-709 - it includes IAC gasket and another gasket I'm unsure what it is.
Car: 88 Firebird Formula
Engine: LO5 5.7 TBI/Ebl Flash
Axle/Gears: 2.73 stock rear end
