is this corvette stuff or l98??
Old Dec 7, 2003 | 07:44 PM
irocnroll89's Avatar
From: previously OKINAWA JAPAN,georgia, now new england
Car: 1989 IROC--1989 T/A
Engine: 5.7 TPI in both
Transmission: W/C T-5 in both
Axle/Gears: B/W 3.27 in both
Ok so i pulled the oil pan off, and found the vette one will not work on the T/A. Now bolted to the main caps is a baffle plate. Is this a l98 plate, or corvette specific? It is important cuz, i now have to mod my 305 pan to fit it.
Also I have found that i can't use my 19,000 mile roller timing chain, on this non roller block. I wasn't aware of a difference, but it won't fit.
All help welcome, as i don't remember what baffling was on the Iroc.
shawn
Old Dec 7, 2003 | 07:58 PM
Insomniac92z28's Avatar
Car: 92Z28
Transmission: A4
I'm not sure on the windage tray but I really don't think it will make too much differance if you use it or not. Stock type (solid) hold oil up where the crank can hit it so they really don't do much. I would take it off and use the 305 pan.
Good luck,
Charlie
Old Dec 8, 2003 | 01:42 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
That's what mine looks like (see sig).
Old Dec 14, 2003 | 07:52 AM
CALIROCZ28's Avatar
Car: '98 Z28 LS1
Transmission: 4l60E
Axle/Gears: 373
I bought a '91 Corvette L98 motor to put in my '89 Iroc and found that the oil pan will not clear the frame. The baffle and wind scrapage is part of the corvette's pan on the '91. I had to find another 1 pc seal oil pan at the bone yard for my '89 fbody.
Old Dec 15, 2003 | 12:56 AM
scottland's Avatar
Car: '82 Z28
Engine: 350HO
Transmission: M4
now i may be wrong, but weren't all corvette 350's 4 bolt mains?
Old Dec 17, 2003 | 04:56 AM
CALIROCZ28's Avatar
Car: '98 Z28 LS1
Transmission: 4l60E
Axle/Gears: 373
No not all Corvettes have 4 bolt mains. Perhaps the earlier ones did.
Old Dec 18, 2003 | 03:51 PM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
The piece on the oil pump iI believe is vette specific, my L98 never had one. Vette oil pans will NOT work on an Fbody, they have the same bolt pattern, but if you compare the two you can see that the sump area has a different shape to it, and the vette's will not clear the Fbody's Kmember.
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
PurelyPMD
May 5, 2016 04:57 PM
Drone358
Dec 10, 2015 08:16 PM
Mr. Chevy
Sep 11, 2015 06:06 PM
scottmoyer
Sep 7, 2015 07:06 PM
