oddity
Old Dec 7, 2003 | 09:25 PM
Electron_Blue's Avatar
Car: 83 Camaro
Transmission: th350
oddity
weird problem....ok my friends 2.8 camaro died while he was driving down the road....you go to start it....it cranks over...but doesnt start...the lights din slightly.....its not the battery cuz we jumped it......i thought it might be the alternator but we cranked it over about 20 times for 20 seconds each,,,,the battery surely woulda died i would think...it was fiarly small....what do you guys think...fuel pump maybe.....coil?......im not quite sure myself....any ideas or ways the single things out and make sure they are ok
Old Dec 8, 2003 | 04:41 AM
ede's Avatar
ede
have you done any trouble shooting? have fire? have fuel? since it'll spin that pretty much rules out the battery and starter.
Old Dec 8, 2003 | 07:07 AM
SeanTimothy's Avatar
sounds like the ignition module...did it just die all of a suddon? or did it slowly crap out??
i miss my 1000+ posts....
Old Dec 8, 2003 | 02:27 PM
Car: 83 Camaro
Transmission: th350
how should i go about checking for fuel......its one thing with a carb or tbi...not used to these other injection systems yet
Old Dec 8, 2003 | 02:38 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Same as you would with any other kind of engine or fuel system.
Squirt some fuel into the intake. If it runs until that fuel runs out, you have a fuel delivery issue.
This isn't rocket science. It's just a car. Engines need 3 things in order to run: air/fuel mixture in reasonable proportion; spark at about the right time; and compression. Now, your bud's car was driving down the street just fine one minute, and the next it wouldn't run. So, it's reasonable to presume that one and only one of th emagic ingredients suddenly vanished, rendering the engine helpless. Right? All you have to do is figure out which one it is. Too easy. Give it fuel, see if it runs; if it does, then the other 2 magic ingredients are stil there. Give it fuel and it doesn't run, then one of the other 2 magic ingredients is AWOL. etc. etc. It's just logic.
Personally, I'd rather have a no-start condition to troubleshoot any day, compared to a runs-terrible problem, or worst of all, a runs-terrible-once-in-a-rare-while problem. That's the kind my wife's cars always seem to develop.
Old Dec 8, 2003 | 04:31 PM
hydric's Avatar
Car: 1985 Iroc-z
Engine: 355 sbc
If that isn't just the truth of the matter.
Old Dec 8, 2003 | 05:12 PM
rustybluebird's Avatar
Car: 87 Firebird
Engine: 350, 416's, 230/230 cam, torkerII, q-jet
Do you mean your 1084 posts, slowmaro?
Old Dec 9, 2003 | 12:00 AM
haha, yeah, i miss those posts....bastards....and i hate the problematic runs like crap every 3 days issues.....
and with ecm controlled cars, its not so simple ......you have to find out whats not happening correctly, then find the part causing it to act funny....which isnt fun with obd 1 cars......i sugegst getting a scanner, or buying mine ...and not one of those "pulls the codes only" 20 dolalr scanners.......you can pull codes with a hair pin. ou need something that tells real time operating values. and even then obd 1 doesnt tell you enough to figure much out. altho is does tell you rpm, engine temp, and other crap thats not too useful when trying to fix a car that DOESNT RUN!!!!
cycleguy04
Members Camaros
35
May 28, 2015 06:22 PM
Bigtommer
Feb 16, 2015 02:01 PM
ericjon262
Mar 2, 2014 01:06 PM
Gumby
Car Audio
Oct 11, 2009 04:06 PM
Elthesh
Nov 13, 2006 09:53 PM
