dist tune up what is needed?
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
I guess the module, pick up coil, gear, shaft, what am I missing, I know rotor, cap, I am just trying to freshen it up.
86Z28, GM 350, Jet perf Q-jet & chip Dual snorkel air cleaner, Edelbrock performer intake, Edelbrock headers, Edelbrock cat-back, Off road pipe, MSD 6AL, Accel Super Coil, Taylor Spiro-pro wires, Rapid fire plugs, Jet fan switch, World class t-5, Hurst Short Throw Shifter, Ram Flywheel, Center force dual friction clutch,Aluminum drive shaft, BW disc rear 3.45's & a posi, PBR calipers, Earls braided brake lines, Polygrapite bushings all the way around, poly tranny mount & torque arm mount, Hotchkis lower control arms & panhard rod, Rancho limiter straps, KYB struts & shocks, Gm Wonderbar, Edelbrock strut tower brace, SSM sub frame connectors, Jamex lowering springs, Carbon metallic brake pads, Crossed drilled rotors, Mobil 1 Tranny fluid & motor oil, GM syntheic rear end oil, K&N, Grant stering wheel, 1,200 watt system, Jet Black Paint, 91 Z28 rims, 92 wing, Tinted windows.
Cap,rotor,ignition module,pick up coil,. That should be it for the dist.
Then do plugs and wires and check timing. Thats about it.
91 Formula
305 TPI 5speed
1LE/G92/WS6
Custom cold air intake w/K&N, SLP airfoil, ported & polished plenum, TB coolant bypass,Crane AFPR (47psi),94 octane,Crane Extruded Alum. 1.6 full roller rockers, Timing set from 4*BTDC to 10*BTDC,MSD coil,MSD6AL, Holley 9mm Annihilator Laser shot 50 wires, Ac Delco cap,rotor and plugs, Bosch O2sensor, SLP 1 5/8 headers,SLP catback,3:73s,JET 195* fan switch, Macewen white face gauges, Autometer gauges, Zoom hi-performance clutch.
Street legal with stock throttle body, runners,intake manifold,cam, and heads. Coming next..9# Procharger!
91 Formula
305 TPI 5speed
1LE/G92/WS6
