85 TA SPEED LIMITER
Old Jan 1, 2001 | 11:03 PM
KEVIN's Avatar
85 TA SPEED LIMITER
i need to know how to get around the speed limiter on an 85 ta 305 tpi
Old Jan 1, 2001 | 11:39 PM
KEVIN's Avatar
p,s i can only get 4500rpm's in drive and 3500 in od! help me vader!
Old Jan 1, 2001 | 11:56 PM
Enkil's Avatar
Well.. while the 4500rpm in drive isn't quite normal... the 3500 in OD is about right, unless you have a modified tranny that lets you run at WOT in OD.
89 iroc-z 305 tbi
everything stock, except for a mirror that fell off
Old Jan 2, 2001 | 04:50 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
What speed are you at at 3500 on OD?
My 86 carbed T/A doesn't have a limiter as far as I know.
I've gotten my car up to almost 160mph a couple of times. I did 145mph last night for some odd reason, new years eve is not the safest night to run fast.
Zepher
'86 Pontiac Trans Am WS6, LG4 305, 5 Speed, CF DF Clutch,
Edelbrock 1406 Carb, Edelbrock Performer RPM 7101 Intake Manifold.
Edelbrock Open Element Air Cleaner: Flowmaster Exhaust, 160* Thermostat,
Grant GT Steering Wheel, MSD HEI Coil, Taylor 8mm Wires, Leather 96 Camaro SS Seats,
Alpine CD+Changer,Alpine V12 Amps, Premier TS-1040C Subs, Polk Audio highs/mids.
Best ET: 14.94@91.67
High Speed Run: 157mph
WS6 Trans Am
Old Jan 2, 2001 | 09:53 AM
KEVIN's Avatar
i only have an 85 mph speedo so i dont know how fast, i can only guess about 115-125. once i shift into od i can run w,o,t and it wont kick down as long as i hold 3rd til it maxes out.
Old Jan 2, 2001 | 12:05 PM
Vader's Avatar
Kevin,
The speed limiter programming is a function of vehicle speed ssensor input, not the engine RPM directly.
The speed limiters on cars equipped with non-Z rated tires are set at around 118 MPH. Cars equipped with Z-rated tires are rumored not to have a speed limit programmed in, but this is not entirely true. The ECM requires some number in the memory address for fuel cut-off, or the car wouldn't run. GM entered teh maximum number in that address - 254. In essence, not many ThirdGens are going to see that limit, so there is effectively no limit.
Later,
Vader
"No matter how hard you try you can't stop us now"
Adobe Acrobat Reader 4.0
Old Jan 2, 2001 | 07:51 PM
KEVIN's Avatar
thanks vader, appreciate the info!
Old Jan 4, 2001 | 11:14 AM
KEVIN's Avatar
thanks for everything guys!!!!
RedLeader289
Sep 23, 2015 06:50 AM
adelane
Sep 9, 2015 08:51 PM
SG91camaro
Sep 5, 2015 10:27 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
