Afr Heads
Old Dec 8, 2003 | 10:10 PM
DTL504's Avatar
Car: 84 Z28 Convertible 2 Seater
Engine: Dart Little-M SBC 400
Transmission: Pro-built Automatics 700R4
Axle/Gears: Strange Engineering 3:73
Afr Heads
I bought all the parts to my car except the heads, so I sent AFR a email for their recommendation. I was planning on using the AFR-195 for my street engine but here is what they had to say:
Dear David,
The 210cc heads will be the best choice for your combination.The heads will be fully cnc and will flow 285cfm intake and 220cfm exhaust.The heads will have a spring that will handle a solid roller good to .670 lift. The heads will come in a 76cc or 66cc chambers.The heads will start at $1450 complete ready to bolt on. and $739 for a bear as cast head with just seats and guides only. these heads are not finished and will require alot of work. We are about 6-8 wks for delivery.Thank you for your interest in our cylinder heads.Please feel free to call with any questions that you may have.818-890-0616.
Sincerely,
Marc
Sent: Monday, December 08, 2003 8:02 AM
To: 'info@airflowresearch.com'
Subject: Head Recmmendation
Needs heads recommendation for SBC 400 Street/Weekend Warrior that will need springs for Solid Cam.
What is the price complete and bare.
SBC 409
4.165 Bore X 3.750 Stroke
Compression: 10:44:1
Cam: Lunati/UDHarold Solid Mechanical Cam
Grind: 280/284F10
Adv. 280/284@.020
Duration: 247/251@.050
Lift: 525/530 w/1.5 rockers
Lobe Separation: 110
Centerline: 106
Carb: 750 Holley Vac. Sec
Converter: 3000stall
Trans: 700R4
Rear: 3:73
Intake: Edelbrock Victor Jr.
26" Tires
Wiseco Tru-Pro flattop Piston 5.4cc
Scat 9000 Crank 3.750 x 6.000 Stroke
Eagle H-Beam Rods: Forge 6"
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
92projectcamaro
Jan 18, 2016 08:00 AM
New2Chevy
Sep 28, 2015 12:35 AM
z28guy134
Sep 1, 2015 11:50 PM
