Should the Radio Antenna Retract when cranking
Old Dec 9, 2003 | 02:41 AM
IrocZed's Avatar
On Probation
Car: 03 BMW Zed4, 87 Camaro IrocZed 305 TPI
Engine: 2.5 I6, 305 TPI V8
Transmission: 5 spd., T700R4
Hi,
In contuination to my starting problem, i noticed that when i turn the key to cranking position my starter just makes a loud click noise.
Today while checking ground wires and trying again i saw that the radio antenna starts to retract and upon releasing the key it goes back up again.
Is this normal or an indication of some short of some kind.
Thanks Sean
Old Dec 9, 2003 | 06:04 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
It is normal.
The radio gets no power when the key is in "start", so the antenna will be told to go down.
Check your battery cable connections at the battery. Take them off and clean the corrosion out of them.
Old Dec 10, 2003 | 04:28 PM
IrocZed's Avatar
On Probation
yes i have been thinking the same. I did have a corroded ground connecton which i cleaned up.
But as you said i plan to chekc the battery connection to the starter B terminal and the fusible links.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
RedLeader289
May 28, 2019 01:47 PM
djmarch
May 8, 2016 11:32 AM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
skinny z
Oct 5, 2015 06:23 PM
