starter teeth 168 or 153?
Old Jan 4, 2001 | 05:12 PM
tzweelz's Avatar
starting to really need a new starter. was thinking about getting a mini high torque one. found 2 different ones pretty cheap one is 168 other 153. i forgot which i need, i know an ls1 starter does not work but an lt1 does which i may try to get if i dont get the HT starter.
Old Jan 4, 2001 | 05:44 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Get the CVR with both bolt patterns.
Old Jan 4, 2001 | 08:29 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
It must be really cheap or an OEM starter. Just about all the aftermarket mini starters I've seen will work with both ring gears.
Stephen's racing page
87 IROC-Z Pro ET Bracket Race Car
383 stroker (carbed) with double hump cast iron heads and pump gas
454 Big Block buildup now in progress for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857 altitude corrected to 11.163
Best MPH on a time slip: 117.87 altitude corrected to 126.10
Altitude corrected rear wheel HP based on power to weight ratio: 476.5
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
3rd gen money
Oct 11, 2019 09:57 PM
Gunner242
Dec 25, 2015 04:49 PM
gord327
Oct 3, 2015 01:25 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
