is 10.9to1 to much compression for daily driver?
Old Jan 5, 2001 | 12:33 AM
bad camaro RS's Avatar
i thought i had about 9.5to1 with 64cc stock heads but come to find out i had 10.2 i bought a set of afr 195cc milled to 58cc so im stuck with them now but should i be alright with 92 octane gas? thanks
1992 camaro RS
373 10 bolt rearend
ssm sfc's
87 350 TPI
bored 30 over
compucam 2032 with 1.6
482-495 LIFT 214-220 duration full roller rockers
msd6AL
1 5/8 headman headers
2 `1/2 flowmaster exuast
k&n filters gutter air box gutted maf
3 pc under drive pulleys
no emissions no egr etc
custom ED Wright chip
eddelbroc intake base and runners ported plenum
midly ported and polished stock heads
Taylor 8mm wires
B&M mega shifter
gutted maf/airbox
hotchkis lower control arms
3" exhuast cutout
homemade cold air intake
2000 tci stall
700R4 with B&M shift kit
new best ET 13.5 @104.66
Old Jan 5, 2001 | 08:23 AM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
With aluminum heads and enough overlap on the cam, you should be alright.
Miles
88 427 Camaro
12.18 @ 113mph 1.75 60ft
www.koolmeister.com
Old Jan 5, 2001 | 09:19 AM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
If you are planning on keeping the cam you have you will probably have a problem. The cam you have in your sig file is designed to make high cylinder pressure at low speeds. The limit is probably 10 or 10.25 with pump.
There is probably a .055 thick head gasket that will drop it about .15 point from a .035 but I think you might have to find a cam with a little more duration. If you try to get something with a much tighter LSA (which is really what you need), the closed loop operation will be affected.
For 87-89 Corvettes, Camaros and Firebirds factory equipped w/350 TPI engines. Adj. Fuel Pressure Regulator (99470-1) is recommended for maximum performance. (50 state legal for listed applications, C.A.R.B. E.O. D-225-22). Basic RPM 2000-5500 CompuCam
2032
Cam Specifications
214 220
270 276
LSA 112
Valve timing events
0 34
47 (7)
.452
.465
F.I. 57 Belair
Aug 23, 2021 01:09 AM
my86bird
Oct 23, 2015 12:20 PM
rsrookie
Sep 5, 2015 07:08 PM
Vassago
Convertibles
Sep 4, 2015 09:37 PM
