how to tell if you have a coolant leak
Old Jan 4, 2001 | 09:32 PM
85F-body's Avatar
i just resently made a throttle body bypass and am not sure if it is leaking, i watched it run and there was'nt a big leak but the tube looked like it might have been slowly leaking i just wanted to know if there would be any signs if it gets really bad
THANKS
Old Jan 4, 2001 | 10:32 PM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
OK, I'm confused...
If it leaks.....its leaking.
Seriously, keep an eye on the area you worked on, if you see any coolant leaking at all, its too much.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
GO #3
Old Jan 5, 2001 | 12:15 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
If you have any anti-freeze in your cooling system, you will most likely smell it. It has an odor that you will never forget.
Old Jan 5, 2001 | 03:47 PM
85F-body's Avatar
i thought that it might have been slowly leaking out but then after i drove it today i noticed that there was'nt any leakage
and yes i will never forget that smell i forgot to relive the pressure and the anti-freeze went all over my hands
Old Jan 5, 2001 | 03:54 PM
R.O.B.'s Avatar
You can get a pressure testor. It works nice. The car is cool, yet the radiator gets pressurized. Watch the gage, if pressure drops, look for the wet spot.
Rob
'86 TA 305 TPI
sheachopper
Jul 31, 2019 11:27 AM
RS Reaper
Oct 17, 2018 07:52 PM
ULTM8Z
Oct 2, 2015 01:25 PM
