How to install a cam for dummies???
Old Dec 11, 2003 | 04:18 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
I have my new GM caprice create engine on an engine stand and I bought a ZZ4 roller cam to replace the peanut cam that came with the engine. I have a few questions on how to do the cam swap.
- Do I have to degree the cam (which I do not know how to do) or can I just line up the marks on the gears?
- Do I have to take off the oil pan?
- Should I replace my old distributor gear, if so with which one, there are like 100 on summits site?
- What type of assembly lube should I put on the cam?
Old Dec 11, 2003 | 04:37 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
- Line up the dots.
- Yes, to get the timing chain off. You could "drop it" a little, but since it's on an engine stand, may as well do it right.
- Define "old". If it doesn't look too worn it'll be fine.
- Standard moly lube on just the cam journals. You don't need it on the lobes. AAMOF, putting it on the lobes will make it difficult for the rollers to spin at first. Not good.
Old Dec 11, 2003 | 10:44 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
It is slightly worn. Does anyone have a part number for which gear I need for an 89 TPI setup with a roller cam?
Old Dec 12, 2003 | 07:39 AM
AJ_92RS's Avatar
Your local GM parts dealer might have it.
Old Dec 13, 2003 | 01:09 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Does anyone have a summit part number for the distributor gear?
Old Dec 14, 2003 | 03:55 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
anyone?
anesthes
Mar 10, 2016 10:35 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
theurge
Aug 21, 2015 12:46 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
drathaar907
Aug 6, 2015 04:20 PM
