how to drain gas from tank
Old Dec 14, 2003 | 02:14 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Were swaping in a V8 TPI pump into my GF's 90 RS with a V6 pump for a motor swap. problem is tank is full since we were storing it and didnt think we were goign to get to the swap this year. Any suggs on how to drain? Thanks
Old Dec 14, 2003 | 02:45 PM
hydric's Avatar
Car: 1985 Iroc-z
Engine: 355 sbc
u can squeeze a lil hose down there n syhpon it out...
disconnect a fuel line, turn the key to the on posistion to prime the pump, that will do the trick..
theres a way to jump the fuel pump so it runs constantly through the ALDL connector under the dash, i do not know the pimps to jump but i read its a possible way, do a search for it
theres some ways
a quick search i did for the fuel pump jumper is this
https://www.thirdgen.org/techbb2/sho...ctor+fuel+pump
just skimmed it
Old Dec 14, 2003 | 03:07 PM
ede's Avatar
ede
i use a 12v external fuel pump from napa, cost around 40 dollars. works very good for draining a tank.
Old Dec 14, 2003 | 04:28 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
isnt the v6 pump capable of enough flow to support a tpi setup? a buddy of mine did a v6mpfi to 350 tpi swap on his 89 and didnt change the pump and it runs fine...
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Bohemian
Aug 15, 2017 05:11 PM
ericjon262
Sep 11, 2015 06:07 PM
TBRays98
Sep 6, 2015 05:05 PM
Strick1
Sep 6, 2015 10:38 AM
