what is TPS?
Old Jan 5, 2001 | 05:19 PM
daniel dekay's Avatar
what is TPS?
i just got a trouble code 24 and it recommended checking the TPS. i would like to know what a TPS is, where is it located and what does it do? i have a 350 with a q-jet.
thanks
daniel
Old Jan 5, 2001 | 05:29 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
TPS means throttle position sensor. The carb guys will know how to fix it.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Jan 5, 2001 | 05:31 PM
after further review of the manual i have discovered that TPS is throttle position sensor. my car idles at 2000 rpms and wont calm down. how do i go about checkin the TPS and IAC?
thanks
daniel
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Throttle Position Sensor. It tells the ECM what the driver thinks the car should be doing at the moment.
On a computerized Q-Jet it's located in the front left corner of the fuel bowl, next to the accelerator pump; if you look at your carb closely, you'll see a small green rod sticking out of the top of the air horn touching the pump lever; that's the TPS actuator.
(edit) On a carb car the ECM does not control the idle speed; either your choke is stuck, or you have a massive vacuum leak, or your secondary blades are stuck cracked open, or it's just plain misadjusted.
[This message has been edited by RB83L69 (edited January 05, 2001).]
Old Jan 5, 2001 | 05:50 PM
well heres the next problem, i am scheduled to drive back home tomarrow (saturday). if i cant re-adjust this TPS sensor by then, is it ok to drive roughly 200 miles to home? what kind of problems can i excpect?
another ?, i saw the green lever, how do i adjust it, should i just play with it until the idle calms down. im gonna wait for my dad to come home before i apptempt to do anything, like around 7pm pacific time.
thanks
daniel
Old Jan 5, 2001 | 06:07 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
You could drive it forever and not hurt anything.
The idle speed adjustment is a screw on the side of the carb that the throttle lever rests against. However, if your car just suddenly started doing this, it's unlikely that the screw is the culprit since they don't usually just jump off into some other zone by themselves. More than likely your idle speed problem is one of the other things I mentioned.
To adjust the TPS you have to remove a plug from the carb, which is very hard to do without disassembling the carb. That sort of thing is best done during a rebuild.
I always replace the TPS as part of a CC Q-Jet rebuild; they don't cost a whole lot, go bad alot, and are a pain in the drain. Odds are, if your TPS has worn out, your carb needs rebuilt anyway.
Old Jan 5, 2001 | 06:08 PM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
Not to be rude, but you need to read the replies when you ask a question.
The ecm does not control the idle on a carbureted (LG4 or L69) engine in a camaro. Adjusting the TPS will not change the idle signifcantly.
It does sound like the choke is not opening though. After it is warmed up for about 10 or so minutes, the choke plate should be completely vertical. If not, i'd be checking the voltage to the choke heater. It should be 12 volts when the engine is running.
Good luck.
Working on:
'84 Z28 LG4 305
Added dual elec fans.
145 MPH IROC Speedo
Building 430 HP 350
using primarily GMPP parts.
Block is in shop!
Awaiting results from all 8 ASE tests.
Starting to look like the Kicker poster child!
Old Jan 5, 2001 | 07:33 PM
Vader's Avatar
DD,
Study the diagram in the linked file and find the TPS on your QuadraJet E4Mx.
E4ME.pdf
You'll need Adobe Acrobat Reader to access the file (see below).
Later,
Vader
"No matter how hard you try you can't stop us now"
Adobe Acrobat Reader 4.0
92camaro350cci
Oct 14, 2015 09:29 AM
Fred SS
Oct 12, 2015 11:27 AM
HoosierinWA
Oct 7, 2015 10:15 AM
racereese
Oct 3, 2015 03:46 PM
