norm oil press for 91 z28?
Old Jan 6, 2001 | 02:19 PM
mycarsucks's Avatar
Today I drove a 91 z28 (that supposably has 54k miles). It ran about 30 for pressure. Half an hour later, I drove a 92 RS that had 84k miles, and its pressure was at 60. Both cars were good and warmed up. Just wondering what the norm was?
Old Jan 6, 2001 | 02:40 PM
My90Iroc's Avatar
Car: '90 Iroc
Transmission: 5 spd
30 psi is definitely low. The rule of thumb is 10 psi for every 1000 rpms, but normally, that ratio isn't in effect until 5000 rpm and up, normally 60 or more. The sending unit for the guage could just be bad, when that happened to my the guage showed some pressure, but very low, so if you want to check that you can stick a mechanical oil pressure guage on where the sending unit connects. If the mech. guage shows 30 psi, I'd stay away from that car. Good luck
'89 Camaro RS 6cyl. auto, don't know how much longer I'll have it.
'90 Iroc TPI 305, 5 spd (no mods...yet )
Old Jan 6, 2001 | 04:28 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
35-40 idle 60 highway
my86bird
Oct 23, 2015 12:20 PM
Gunsbee
Sep 7, 2015 07:10 PM
greenyone
Sep 2, 2015 03:39 PM
solocus
Sep 2, 2015 12:14 PM
Navy8125
Aug 21, 2015 09:32 AM
