Temporary 305
Old Jan 5, 2001 | 07:20 AM
Imark's Avatar
Temporary 305
Hi all,
I've still got the 350 on the stand, but in the meanwhile I want to add some punch to the stock carb'd 305. I know there is a real limit so besides the 3" pipes (which will work on the 350) what cam/manifold setup will give the biggest bang for the buck? At the rate the 350's going I'll need to run this motor for another 6-8 months.
"It's not about going fast all the time; It's knowing you can, anytime"
Old Jan 5, 2001 | 08:52 AM
MEANGREEN's Avatar
Hell, stock manifold, 1" open plenum spacer, K&N Stubstack, K&N filter. I wouldn't go spending $ on the 305 when you have a 350 ready to go in, it'll give it a little more grunt, while not emptying your wallet.
Dan Young
1995 Z28/M6
Groton, CT
1985 Z28/A4
(Prospective purchase)
Old Jan 6, 2001 | 09:17 AM
ws6transam's Avatar
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
I spent $850 on my 305 and it goes 101 MPH.
'Course, I spent money on other stuff like the exhaust system, torque converter, etcetera, but as for the long block, $850 really woke it up.
Daniel Burk
http://www.isthq.com/~dan/fcar.html
'84 Trans Am WS6/L69
KB SFC, Moser axles, Torsen Diff. PST suspension, Braided stainless brake lines, Koni struts, 11-inch rear disks,Spohn Adj. torque arm,
Ported 305 heads w/1.94"intake valves, Comp Cams XE262H, Griffen alum. radiator,
Turbine Technologies 2500 stall converter, underdrive pulleys, Crane Hi-6 & more.
1.05g skidpad verified.
New best E/T! 14.039 at 100.82 MPH in 41 degree air at Stanton, Michigan.
Old Jan 6, 2001 | 08:19 PM
Bort62's Avatar
You Also Have the Good Long Block
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver
Livin' the Stereotype
pjsparts
Oct 29, 2025 06:39 PM
db057
Apr 28, 2019 07:45 AM
383cam
Sep 9, 2015 06:01 AM
rsrookie
Sep 5, 2015 07:08 PM
Formula_88AE
Sep 3, 2015 01:47 PM
