What in the world..???!
Old Jan 5, 2001 | 02:33 PM
Enkil's Avatar
While crawling under my car today (something I like doing from time to time) I realized my radiator didn't have an air dam on it. At least, I don't think it did. Every air dam I've seen looks like a ~3" tall piece of plastic that runs from the left side of the radiator to the right, and it's sticking straight down from the bottom of it. My car doesn't have that.
What it DOES have, however, is some weird piece of plastic that's attached to the front bumper. From there, it curves down a little bit (not quite as low as an air dam does), then back up, and then it goes about halfway up the radiator and it's got two holes in it that looks like it would funnel air into two spots on the radiator. The way it's attached at the front of the bumper would prevent it from scooping up any air from the bottom of the car... however... the front of my car has the setup where it's got the big oval hole, with the black piece going through the middle that says "CAMARO" (like I didn't know what kind of car I had), with foglights in the two holes on either side. The way the plastic is set up, it looks like it would scoop the air up from inside those.
Still, I've never seen anything like that. I was wondering if it was supposed to look like that.
89 iroc-z 305 tbi
everything stock, except for a mirror that fell off
Old Jan 5, 2001 | 06:02 PM
ede's Avatar
ede
near as i can tell from your description yeah it's suspose to be like that. i bought the iroc grill for my sons car, sounds like what you described.
ICON Motorsports
1st & 3rd
Old Jan 6, 2001 | 08:54 AM
Baz89RS's Avatar
As far as I can remember your supposed to have both. The one piece that curves from front to back and the 3-4" piece of plastic that runs from left to right....
At least those are what I have under my 89RS...
Glenn
Old Jan 6, 2001 | 04:56 PM
dtpmike's Avatar
you will notice a much cooler water temperature if you add the dam, so id go buy it, its cheap.
Old Jan 6, 2001 | 07:07 PM
Enkil's Avatar
hmm.. Anybody know the part numbef for the air dam?
89 iroc-z 305 tbi
Old Jan 7, 2001 | 01:26 AM
I ROCK's Avatar
Car: 89 IROC-Z
Engine: LB9
Transmission: 700-R4
Just call any gm parts counter and tell them front air DEFLECTOR. Then it will be about 30 bucks. I said "air dam" and they wanted over $200 so you probably don't want that.
89 Iroc-Z LB9 305 TPI auto 2.73 posi:
3" Dynomax "cat" back,K&N filters, TB bypass, 3" pipe in place of cat, cleaned and flow-matched injectors, 180' thermo, mild ignition mods, synthetic oil, kicker sound system, soon to attempt engine swap...
fearthisinc
Oct 24, 2008 06:33 PM
Fuzzystyle
Jul 25, 2007 11:07 PM
Schaz
Nov 21, 2006 10:13 AM
slowfast
Nov 5, 2006 03:32 PM
Firebreed
Northern California
23
Apr 7, 2006 11:19 PM
