Stripped threads on my Oil Pan..:(
Old Dec 15, 2003 | 05:43 PM
H-BOMB's Avatar
Car: 89 GTA
I stripped the threads on the oil pan bolt hole...What are my options? I do not want to replace the oil pan.
is the Heli-coil kit any good?
Old Dec 15, 2003 | 08:13 PM
H-BOMB's Avatar
Car: 89 GTA
HELP
ANybody? ...Help...
Old Dec 15, 2003 | 08:25 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You mean the drain plug?
Old Dec 15, 2003 | 08:38 PM
MikeS's Avatar
There are a few different drain plugs you can use. It is pretty easy to find a parts store that carries a variety of "oversized" oil drain plugs. They have like three different degrees of oversize. Also, there are some different rubber type plugs that you could use. Some have clamp down over/into the hole using springloaded wings on the inside of the pan, and others expand to plug up the hole. I've got one of those on my 81 temporarily and it seems to be holding up alright. Of course, the car doesn't see much use...
Old Dec 16, 2003 | 04:54 AM
ede's Avatar
ede
drill it to the next size over, matric would be my guess, or for a NPT plug. the gasket is just a piece of palstic. like was said there are over size plugs.
1992 Trans Am
May 10, 2023 07:19 PM
Prodigious
Oct 4, 2015 11:20 PM
LittleFranks
Sep 17, 2015 12:22 PM
Thornburg
Sep 1, 2015 03:39 AM
Navy8125
Aug 21, 2015 09:32 AM
