COLD WINTER STARTS... help?
Old Dec 15, 2003 | 11:35 PM
Token's Avatar
Car: 1992 Firebird
Engine: forged 357
Transmission: 700r4, 2200-2400 stall, vette servo
Axle/Gears: stock pegleg 2.73 drum (temp)
so it's about 25 degrees when I decided to start my car today. It was cranking but when I let off the key it didn't turn over. I had to give it lots of gas for it to start, then hold the pedal for a few seconds 1/4 throttle or it would die. I've never had this problem ever before in the three past winters Ive owned the car. What could be the problem, and how do I fix it?
Someone mentioned that I should doublecheck my IAC. I cleaned it this past spring, maybe it's dirty again. I'll get a can of carb cleaner... but what else should I check?
Old Dec 15, 2003 | 11:37 PM
firbird's Avatar
take it off and actually look at it and clean if nessasary if just spraying it dont work
Old Dec 16, 2003 | 10:28 AM
82CamaroZ28's Avatar
Car: 1982 Camaro Z28
Engine: Self-built 350
Transmission: Pro-Built 700r4 w/2800 Vigilante
Axle/Gears: Eaton 3.73 w/Moser axles
You might also want to make sure the choke pull-off (see pic below) on the carb is working properly. I had mine go out on me and it was very hard to start and keep running. It is located on the passenger side of the carb. When you first step on the gas pedal before you start it, the pull-off should completely close the butterfly over the primaries. As soon as it starts up, it should slowly start opening them to keep the car running.
Also I found that in the winter I will usually have to pump my gas pedal a few times, turn it over a few times (to allow the fuel pump to pump some gas to the carb) while still pumping the pedal and then it should start right up and go to high idle.
tmellott89
Oct 14, 2015 02:06 PM
meeklay812
Oct 1, 2015 03:46 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
mfp189
Sep 27, 2015 09:25 AM
