How do I increase my fuel pressure?
Old Jan 7, 2001 | 05:45 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
Can someone tell me how to increase the fuel pressure on my 87 LB9 IROC? I know that I need a new fuel pressure regulator but do I also need a new fuel pump? If not then where does the fuel pressure regulator go and how easy is it all to set up?
Also, I read a tech article and it says you should fit a pressure guage, is this essenbtial?
Finally where can I get the pest parts for the job and how much will it all cost me?
Thanks for the help
Rob
1987 IROC-Z Auto (LB9)
Black/grey with the stance of a streetfighter
Mods
Custom exhaust. 4 Inch pipe from the headders all the way back to a single muffler at the rear. No Cat.
Future mods:
K&Ns
RAM Air
New Underdrive pulleys-either March performance pulleys or Auto Specialties Performance
Air foil
Old Jan 7, 2001 | 06:29 PM
I ROCK's Avatar
Car: 89 IROC-Z
Engine: LB9
Transmission: 700-R4
Look a few pages back at one of my posts or elsewhere Vader has posted an article about how to convert a stock fpr into an adjustable. You need a guage if you want to know what the pressure is.
89 Iroc-Z LB9 305 TPI auto 2.73 posi:
3" Dynomax "cat" back,K&N filters, TB bypass, 3" pipe in place of cat, cleaned and flow-matched injectors, 180' thermo, mild ignition mods, synthetic oil, kicker sound system, soon to attempt engine swap...
Old Jan 7, 2001 | 06:35 PM
88irocz28's Avatar
Car: 1994 Trans Am
Engine: 5.7L LT1
Transmission: 6-speed
I think there's an article on converting your stock FPR into an adjustable one in the tech articles section. The pressure gauge will fit on the schrader valve on the fuel rail.
'88 IROC 305 TPI
Crappy 700R4 slushbox
Gutted airboxes
180 degree T-stat
Advanced base TPS voltage
Relocated IAT sensor
Momo steering wheel (gotta luv it)
Ram-air setup coming soon
Flowmaster muffler (puke)
Taylor SpiroPro wires
Accel cap and rotor
Kills: '94 Z28, Olds Aurora V8, bunch of Mustangs, T-birds, ricers, and others who assumed a 12 year-old car would be too slow.
Old Jan 7, 2001 | 07:09 PM
theformula's Avatar
Look at the article for the homemade afpr. You can buy a FP gauge at Lowes for $7. Don't waste your money on the Hypertech or Accel one.
91 Formula
305 TPI 5speed
1LE/G92/WS6
K&N, SLP airfoil, ported/polished plenum, March pulleys, TB coolant bypass,Crane AFPR(47psi),Crane Gold 1.6rrs,MSD coil,MSD6AL, Holley 9mm wires,Bosch O2sensor, SLP headers & catback,3:73s w/Auburn posi,180* t-stat,JET 195* fan switch, Macewen white face gauges, Autometer gauges, Zoom hi-performance clutch.
Street legal with stock throttle body, runners,intake manifold,cam, and heads.
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
