EGR Code 32, Runs fine though?
Old Jan 7, 2001 | 05:07 PM
Twilightoptics's Avatar
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
'85 Z28 305 TPI
I've had the code 32 for a while now. The check engine light only comes on when the car is cold... and stays on until the next start, where it doesn't come on at all. Car shows no running difference when the light is on or off. Both ways it runs great. The big orange glow is just wants annoying me. How do I check for things, before I go randomly replacing the solenoid, and valve, and taking the plenum off etc.
Old Jan 7, 2001 | 07:36 PM
SGT SWEETPANTS's Avatar
Nobody wants to reply o this topic because it has been on here so many times. My suggestion is to go to the tech articles on this site and read the article dedicated to your exact question. If that does not answer your question, come on back with specifics and someone will give you some help.
'86 IROC-Z, 305 LG-4, T-5, T-Tops, 50k Original Miles, K&N Air Filter, Jet chip, KYB Shocks/Struts, Centerforce Dual Friction, B&M Ripper Shifter
Old Jan 7, 2001 | 07:41 PM
CamaroEFI's Avatar
or you can take out the bulb like i did
Old Jan 7, 2001 | 08:01 PM
I ROCK's Avatar
Car: 89 IROC-Z
Engine: LB9
Transmission: 700-R4
If you removed the smog equipment on a tpi you will get an intermittent code 32 but nothing is wrong. Just clear the code and don't worry about it.
89 Iroc-Z LB9 305 TPI auto 2.73 posi:
3" Dynomax "cat" back,K&N filters, TB bypass, 3" pipe in place of cat, cleaned and flow-matched injectors, 180' thermo, mild ignition mods, synthetic oil, kicker sound system, soon to attempt engine swap...
Old Jan 7, 2001 | 10:47 PM
I haven't removed anything. I've checked for vacuum leaks, visually. Nothing wrong. I'm going to take the Plenum off to port and polish it... should I just go ahead and replace the valve, solenoid and check the connections more efficiently? Are those the only 3 things that can set off the code? I would assume it's the original EGR with 127k on the car.
'85 Z28 305 TPI. Edlebrock Strut Tower Brace. IROC wheels. Fog Lights. Upcoming mods: Headers to tail pipe performance. Rear shocks. Panhard Rod. Sway Bars. MSD. New Intake.
theshackle
Mar 5, 2017 06:37 PM
apo_bailon15
Mar 28, 2016 05:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Kaweh
Aug 9, 2015 02:54 PM
Sherpajames
Aug 7, 2015 06:56 PM
