Suggestions for a new cam
Old Dec 17, 2003 | 05:06 AM
CALIROCZ28's Avatar
Car: '98 Z28 LS1
Transmission: 4l60E
Axle/Gears: 373
Hey guy's I want to replace the cam in my '89 Iroc. It has a '91 Corvette L98 aluminum heads. The cam in it now is stock. I would like a somewhat radical cam but not one that is going to make my car not idle. What I'm looking for is a big power gain with fair idle quality. Any suggestions on a brand and specs would be appreciated. Any cam and lifter packages any of you guy's know of or are using? I don't plan on doing any head work just yet but the heads are on my list for future mods.
Old Dec 17, 2003 | 10:18 AM
BadBlue91RS's Avatar
Car: 1991 Camaro RS
Engine: Briggs & Straton
Transmission: Centrifical Clutch
I can suggest a cam.
Comp Cams Xtreme Energy
Grind: XR258HR
Lift: .480''/.487''
RPM Range: 1000-5000 RPM
I think it's a good moderate cam, and should yeild good results. You MAY need some custom chip tuning with it, but I'm not sure.
I'm sure someone else can correct/help me out here.
Good luck finding the cam you want though!
Old Dec 17, 2003 | 11:27 AM
CALIROCZ28's Avatar
Car: '98 Z28 LS1
Transmission: 4l60E
Axle/Gears: 373
To add to what equipment I already have. I have a Jet Off road Stage ll chip. The computer is that of a '90-'92. The plenum and runners are ported and has a BBK 52 mm Throttle body, Adj fuel regulator, MSD 6A ign HEI Mallory dist. Gears are 3.73's I think.
Old Dec 18, 2003 | 02:18 AM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
You MUST stay under .460 lift with those heads.
An LT1 cam would work nicely.
Old Dec 18, 2003 | 02:44 AM
Car: 1991 Camaro RS
On that note, I've got a LT1 cam that I don't need. $25 and it's yours. Hit me on AIM at BadBlue91RS.
Old Dec 18, 2003 | 04:23 AM
CALIROCZ28's Avatar
Car: '98 Z28 LS1
Transmission: 4l60E
Axle/Gears: 373
Can you send me the details about your LT1 cam and is it new or used? The price sounds reasonable. I don't use aim.
email about the cam's spec's to CALIROCZ28@msn.com
junkcltr
Aug 2, 2019 11:12 PM
transamgta87
Sep 1, 2015 07:07 PM
camaro71633
Sep 1, 2015 10:24 AM
InfinityShade
Aug 22, 2015 08:00 PM
drathaar907
Aug 6, 2015 04:20 PM
