Stroked?
Old Dec 17, 2003 | 10:54 AM
Jesus's F-Bird's Avatar
Car: 83 Pontiac Firebird S/E
Transmission: Borg Warner T5
Stroked?
What does it mean to stroke an engine ? is it similar to boaring ? or is it the reverse ? Does it give lots of power, sorry for the really n00b question
Old Dec 17, 2003 | 11:27 AM
ede's Avatar
ede
means to increase the length of stroke over stock destroking would be to reduce the stroke length.
Old Dec 17, 2003 | 11:56 AM
thanks
Old Dec 17, 2003 | 04:24 PM
Rippin92RS's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Transmission: GM T56
Re: Stroked?
It gives a good HP increase but really shines in the Torque department...
-Rippin
Old Dec 17, 2003 | 11:23 PM
stevedave454's Avatar
Car: 91 S10
Re: Re: Stroked?
-Rippin
uh-oh here goes a big discussion again...
but you can get more HP out of destroking too, just have to turn it to higher RPM's which it is capable safely with a shorter stroke...
also maybe i missunderstood the question but, the crank shaft has a specific length for its stroke (3.48" on a 305/350... 3.75" on a 400) and the bore is the diameter of the bore (i forget the 305 bore, but 350 = 4.00" and 400 = 4.125") you can only bore a motor a little bit, and therefore does not increase cubic inches very much, stroking it does however, but the longer stroke puts more stress on the engine and can not be turned to as high of rpms... a 383/400 is a great street motor though
Old Dec 17, 2003 | 11:25 PM
Car: 91 S10
Re: Re: Re: Stroked?
correction... the bore is the diameter of the cylinder
junior419
Apr 7, 2025 11:35 AM
randy210
Oct 15, 2015 03:43 PM
dusterbd
Sep 29, 2015 08:40 AM
C409
Sep 23, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
