Cam swap time: How do I get this out of the way??
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I am starting my cam swap and I got everything out of the way. I only need to remove the valve train and harmonic balancer and timing chain I am am set. I have the radiator out of the way but my AC radiator (cannot remeber what this thing is called) is right in the way. I cannot swivel it out of the way because the line connected to it are hard lines and I do not want them to bend or kink. If I understand correctly I cannot just remove them because all the freon will escape and that could be a safety hazzard. I need this out of the way so that I have enough room to get the cam in and out.
No way to get the cam out without removing the A/C condenser. Neither Freon (old stuff) nor R-134a (new stuff) is hazardous to you in any way. Freon is an ENVIRONMENTAL hazard because it can help burn an even bigger hole in the ozone layer than we've already got, but it won't hurt you and is not flammable or anything like that.
If your car is currently Freon (R-12) based that stuff is worth a LOT of money. You can sometimes work a deal with a local A/C shop so that they can remove and keep it for themselves, and will convert and charge you with R-134a later. Probably not an even swap, but you can often get them to knock quite a bit off the price.
Worst case- pop the line off yourself and vent it to atmosphere (if you can live with yourself over the environmental catastrophe you're causing)
You can, and I recommend, that you convert over to R-134a when you go to recharge your A/C system. Way WAY WAY cheaper than putting Freon back in.
You can, and I recommend, that you convert over to R-134a when you go to recharge your A/C system. Way WAY WAY cheaper than putting Freon back in. Thread Starter
Car: '90 RS
Engine: 377 LSX
You can, and I recommend, that you convert over to R-134a when you go to recharge your A/C system. Way WAY WAY cheaper than putting Freon back in. Yep, just unscrew the fittings. When it's done hissing, she's empty. Put some clean rags in the ends of the hoses- you don't want any more dirt and moisture getting in there than necessary if you ever intend to reconnect and use the A/C system again.
Car: '90 RS
Engine: 377 LSX
Car: 1989 GTA
Engine: 383 Miniram AFR195
Transmission: Tremec TKO
Axle/Gears: BW 9 Bolt/3.70
-Schultzy
Car: '90 RS
Engine: 377 LSX
Originally posted by Schultzy89GTA
I have done it twice this year. Just moved it out of the way. AC still blows nice and cold. :shrugs:
-Schultzy
-Schultzy
I gotta join in here because Im also swapping cams this winter. I was just gunna let the freeon go. Its so small that you probably wont put a dent in the 0zone and its probably worn off or leaked out. Unless your ac blows cold, you really dont need to worry about it. Just make sure no cops roll past your house when you do it.
I'm not trying to save all the bunny rabbits...but the freon does cause some nasty reactions in the atmosphere. I like the mechanic swap idea. Let them deal with it, and be on their conscious, or lack thereof.
Car: '90 RS
Engine: 377 LSX
Originally posted by 83 Z28 HO
Theres a good guide in the tech articles section of r-134a conversions. It looks pretty good.
trust me, the small small amount you have in your car wont do much. You probably killed the ozone a long time ago when it was leaking out!! I know Im gunna do it with the kit I have.
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
Freon IS dangerous. Don't just crack the fitting. Uncap the valve coming out of the heater/ac box and hold it down with a screw driver. If you directly inhale freon or get it into your eyes BAD THINGS WILL HAPPEN.
Car: A Camaro
Engine: Weak
Transmission: Weaker
AHHH, JUST MOVE IT OUT OF THE WAY!!! AHHH!!
I just moved the condensor out of the way; it should just pivot out of the way. There are hard lines, but somewhere along the way there are rubber lines, you can just move it! Just be careful not to crush the fins!
Tony
Tony
Car: 1989 GTA
Originally posted by ShiftyCapone
How exactly did you do that. I tried it earlier today but the hard lines sorta anchor it in place. I do not want to kink them either. Didn't some 3rd gens come with non-hard AC lines while others did? I thought I saw a post awhile back were poeple were arguing about AC lines but they were both correct because GM switched the style lines.
I should have known that there would be differences between all of these cars. On my car it is a flexible hose after the hard lines. It gave me enough movement to get things out of the way for the cam swap and later the engine swap.
If you are able to move them, like Tony says, be very careful with the fins.
Good luck with the project.
-Schultzy
Car: '90 RS
Engine: 377 LSX
Shifty,
-Schultzy
Shifty,
-Schultzy
Car: 2002 Harley Nightrain
Engine: twin cam 88ci
Transmission: manual
mine moved without any problem, same car as yours, a/c still blows cold. Maybe if mine is r134a and yours is freon, that might explain the hard routing difference? I had a bitch with those two supports though. You'll find that they cross exactly where the cam needs to be pulled out. I had to unbolt mine.
Car: '90 RS
Engine: 377 LSX
Car: '82 Z28
Engine: 350HO
Transmission: M4
i just put a cam in my motor this last weekend. my a/c was already discharged, so that wasn't a problem, but those cross braces do get in the way. You can just unblot one of them, and then bend the other one out of the way, and you should be able to get the cam out no problem.
Car: 4
Engine: 6
Transmission: 5
Don't hack your car, or de-value it by destroying the A/C, if you can help it. That may come back to bite you later.
Just move the condenser and the compressor together off to the side out of the way. The rubber part of the lines will allow everything plenty of room to move around. You don't have to hack anything or break the law by venting the Freon or do any other unpleasant thing.
Car: '90 RS
Engine: 377 LSX
Well maybe if I move things a round I can get some more slack in the little bit of soft line that there is. I geuss I will try to pivot it up. Thanks for the tips.
Car: '90 RS
Engine: 377 LSX
Well I got it to pivot out of the way. Seems that there is a little screw that holds the hard lines down that was hidden. took that out and VOILA, everything now moves.
Car: '90 RS
Engine: 377 LSX
Glad to hear you are on your way. What cam are you going with?
-Schultzy
-Schultzy
Car: 84 camaro Z28
Engine: 434sbc
Transmission: powerglide
Axle/Gears: moser 9" with 411 posi
if i were you i would call someone and have them pull the old R12 or R134a. both are harmful. if you directly inhale you could have a big problem. not to mention the fact that R12 and R134a can freezes your eyes within a fraction of a second. i have an ASE cetification to legally buy, sell, and service R12 and R134a units. this stuff can be very bad if don't know what you are doing.
Car: currently thirdgenless!!!
Shifty,
Chris and I just did my cam today. I does move out of the way. You have to move it up a bit and them rotate it as if the hard lines were the pivot point. Try that. Also I think one of the hard lines might be fastened to the body. Follow the line and check it out. If you undo that one, It might move a little more.
Car: '90 RS
Engine: 377 LSX
Originally posted by azvolfan
Shifty,
Shifty,
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Hey Folks..... Just an aside on the hazards of venting refrigerants. Be it R-12, or R-134a. both come out of the valve at an extremely low temp. Frostbite in less than a second, loss of exposed body part shortly thereafter. Not good. Also, R-12 (freon) IS flamable. The products of said combustion are LETHAL!!! So, NO OPEN FLAMES!!! (hhhmmm, an interesting statement on a bullletin board, eh?)
Also, while one person venting refrigerant to the atmosphere may not have much of an effect, what about 50 people thinking, well, it's only a little.... or 100? or 10,000???? This is why our atmosphere is having issues..... It only costs about 25 bucks to have the system evacuated by someone with the correct equipment, and some folks will even PAY for the R-12 extracted.... Though they are few and far between. Pay the money, save the environment.
Now then, I have some trees that need a hug.
Later
Later
Car: 92 Camaro RS
Axle/Gears: 3.73 Truetrac
I remember reading something on here in the rules that stated no talk of illegal acts... or something like that... suprised that this post made it this far...
Car: '90 RS
Engine: 377 LSX
Car: '89 Formula 350 & '86 Z28
Engine: L98 & 355ci
Transmission: 700r4 in both
I am actually a 609 certified and heres a blurb....
Its called "intent to vent" and if caught a business can be punished by a $25,000 fine and 5 years in prison. I cant recall what the implifications are on a personal level.
Chlorine is what is so bad in R-12. (1) molecule of R-12 will destroy 100,000 ozone molecules. So even a little does alot of damage.
Not only will it cause frostbite, blindness...it can kill you if inhaled, it displaces oxygen and you suffocate. Not to mention the increase of cataracts, skin cancer, and loss of immune systems ability to fight off intruders, from increased UV rays. All fun stuff
If you open your system and do not cap it properly you will allow moisture in and it can cause huge problems, from dessicant failure to the moisture reacting with the refrigerant and forming acid, which will eat the system from the inside out.
Glad you are doing it right!!
Car: '90 RS
Engine: 377 LSX
Car: '94 Corvette
Holly crap!!! You guys read everything the media throws at you.
Have an open mind people, and research and judge for yourself!
There is ZERO proof that links freon to ozone depletion. ZERO
Not saying freon won't destroy ozone (that F'in lighten creates btw!!!), it's just liberal college professors can't prove a gas like freon, which is many time heavier than the atmosphere, gets up to 100,000 something feet?
My brother has an EPA degree, and we get into this argument all the time. wind picks it up...whatttt - is that what the teach you in school?
Sounds like an episode of BULL *HIT is being born
BTW: Chlorine is not man made. (see. element 17)
Just to make it clear, if I remember right the laws applied to people with 609's. ...and yea I have one, and yes I laughed my *ss off at the test material.
I encorage you to upgrade your AC system also, because of the cost. nothing more. R-12 is probably upwards of 30-50 bucks a pound now, unless you get it from Mexico
Ron
Ron
Engine: L98 & 355ci
and its not 100,000 feet thats 19 miles up
Edit: I was saying 100,000 ft is 19 miles
Car: '90 RS
Engine: 377 LSX
Shifty,
Let me know how it is running after the cam swap. I'm having a problem getting mine to run right.
Shifty,
Engine: L98 & 355ci
gravity
I'm sorry, it's 10 to 25 miles up...
gravity
Car: 1987 Z28
Engine: 383 Single Plane EFI-NOW RUNNING!
Axle/Gears: Not there yet...
OK. R-12 is NON-FLAMMABLE, NON-TOXIC, let's get that straight. I just looked at a drum in my shop and it says so right on it, of course I already knew that being certified by the EPA to handle refrigerants. The bodily dangers of refrigerant are:
1)Frost bite, obviously.
2)Since it is heavier than air it can deplete the oxygen when present in large concentrations close to the floor.
3)When exposed to an open flame it decomposes and produces Phosgene gas which is very deadly. If you've ever smelled it you won't forget that odor.
I get a good laugh at all the wive's tales about refrigerants and refrigeration in general, even from some people who should be in the know. I do refrigeration and A/C work for a living.
And don't give me that crap about ozone depletion. The only thing scientists have been able to discover for sure is that chlorine will deplete ozone. They also know that the ozone "hole" varies in size over time as a matter of it's nature. Of course, you won't hear that from the mainstream media. IMO it's just a bunch of alarmist, reactionary
Indoctrination, if you will..............
Indoctrination, if you will.............. Supreme Member
Shifty,
As far as the cam and distributer, I left that reinstall up to Chris (ChrisFormula355) he has done many of these and knows his stuff pretty well.
I am leaning toward one of three things.
1. major vacuum leak
2. clogged injectors
3. major tuning issues.
What do you mean by a base chip??
Car: '90 RS
Engine: 377 LSX
Shifty,
Shifty,
By base chip I mean stock chip. I bet that is your problem. Your car will run llike poo with a new cam and stock a bin.
Car: A Camaro
Engine: Weak
That's not exactly true, my car runs fairly well with the LT1 cam and just a VAFPR. I'd definately recommend hooking up a laptop to see if the computer's freaking out, it would also tell you if you have a vacuum leak. Spray some carb cleaner around the places you think a vacuum leak would be and if you notice a difference, there's your leak.
Tony
Tony
Concerning factual information on the ozone layer: In brief...
Possible link to destruction of the stratospheric ozone layer (the only layer that absorbs the far ultraviolet wavelength). Humans can put on hats and sunscreen. Plants and animals can not. Its unclear how animals and plants respond to the ultraviolet.
The elemental chlorine atoms is what does the destruction. One Cl atom (nonconsumed catalyst) can destroy approximately 100,000 to 10,000,000 Ozone molecules by converting them into regular Oxygen molecules. Most chlorine is found in the from of salt in oceans or underground. Elemental chlorine (highly reactive) has few natural ways to get to the ozone layer. The only naturally occuring chemical that can transport chlorine high enough is methyl chloride, which is produced biologically in shallow oceans. 3% of this reaches the ozone layer. Chemically active ultraviolet in a certain range is strong enough to split up the methyl chloride (and other chlorine compounds) releasing the chlorine atoms. With only methyl chloride, the ozone remains in balance with nature (steady state). Methyl chloride has a lifespan of about 2-3 years in the atmosphere. CFCs (freons) have lifespans of 80+ years in the atmosphere. Possible repurcussions won't be known for many years.
Humans produced synthetic chlorine-containing compounds starting in the early 1900s. CFCs (freons) were 1st developed for household refrigerants...They are nontoxic, nonflammable, invisible, tasteless, odorless, non-almost everything. They replaced toxic household refrigerants, saving lives.
As far as known, the only process for removing CFCs from the atmosphere is their slow transport to the top of the ozone layer, where they are attacked by the ultraviolet light, destroyed, thus releasing the chlorine to begin reactions with the ozone.
The only method we know at this time to protect the ozone layer is to limit the emission of those materials that can harm it. The threat is severe enough that international conferences have been held and declarations and treaties adopted that commit the nations that produce the CFCs to restrict and eventually eliminate their use.
Car: 82 z28
Engine: 355
Transmission: 350
Think about our roof and all that rains back on us. I can admit I'm one of the first people that will would and did hack emission stuff after learning how much more extra power I will get from it.I have nothing more to say cause my car has'nt had to pass emissions since 79
Car: '94 Corvette
Again, EPA propaganda. Nothing there says the Freon came out of your car and makes a huge hole in this ozone layer. Not word one...
Ohh that's right thunder storms every hour, every minute of every day transport it up in the form of a giant freon bubble.
They always invent some bs crap science to explain that every damn thing is destroying the planet.
Did anybody see the one where they went around at a save the world ralley, and had people sign a protition to band diHydrogen Monoxide. These people where signing it right, & left. Guess what they wanted to band -- yeap thats right -- water !!!!
...and trees, I burn them to roast my chestnuts
-=Merry Christmas everyone=-
Ron
-=Merry Christmas everyone=-Ron
It's proven that there are natural and unnatural causes of ozone destruction. I personally believe nature will take its course, and there is nothing catastrophic to worry about. The EPA is an entirely different issue, and needs to be stripped of the majority of its power IMO.
As far as transportation in the atmosphere...I'm not going to dwell on it. I'm not trying to save all the bunny rabbits. But if one doesn't have respect for their living environment, then they don't have repect for themselves, much less anyone else.
Take it for what its worth...
Merry Christmas and Happy New Year
