If I disconnect the air pump, how much more hp?
Old Jan 7, 2001 | 11:59 PM
matthew's Avatar
My engine has a seperate belt for the air injection pump. If I cut the belt, how much more hp can I expected from the less drag on the engine? Would it be noticable?
yellow 86 Camaro
LG4 700R4
Pioneer head unit
Kenwood speakers
Infinity Beta Digital 300 amp
2 Infinity Perfect 12s
Old Jan 8, 2001 | 01:08 AM
evilho7810's Avatar
I think if you remove the air pump, power steering, and a/c belts you might get a tenth or two.
Old Jan 8, 2001 | 07:49 AM
Engineboy's Avatar
Car: yep
Engine: uhuh
Transmission: sure does
Nothing you will ever feel.
ASE Mechanic/Machinist/Smog Tech
1999 NBM Trans Am
1986 Chevy 3/4 ton pick up
1981 corvette
1995 Kawi ZX6R
GO #3
Old Jan 8, 2001 | 08:51 AM
jrr's Avatar
jrr
It would be a performance placebo. It would give you an increased sense of ownership over your car by disabling a parasitical device imposed upon you by the EPA. Cutting that belt satisfies the rebellious impulse. Enuff of that psychology B.S...
The pump itself creates very little drag. It's the A.I.R tube extensions that stick into all eight exhaust ports that are a greater impediment. You might find a few extra HP by removing those 3" extensions. Just remove the AIR manifold and reach in with a 1/4" drill bit, or something like it, turn the bit until it "bites" and then pull each one out. Then put the AIR manifold back in and let the smog pump do its thing to keep the CCC happy.
Ghettobird52
Jul 5, 2024 11:18 PM
TheExaminer
Aug 26, 2015 04:59 PM
Dialed_In
Aug 20, 2015 01:45 PM
mcquigg
Aug 13, 2015 02:26 PM
